trunk
Originally posted by atulb84
where is the switch or whatever that disables/enables the trunk to be opened from inside? is on on the bottom piece once the trunk is open or on the top when the trunk is open?
open the trunk
look inside right under the latch
there is a small hole in the trim; there you can see the piece that just slides up and down to disable the inside trunk switch
for others that want to know
atulb took a good pic that shows the lever inside the trunk
this pic is taken from inside the trunk looking out at the bottom part of the trunk liner (which would be right where the trunk latch comes down to meet it)
you can see in the pic a piece of metal pointing towards you and you can just slide this down to disable the trunk pop button in the car; then you can just open the trunk with a key (hopefully your key works in the trunk)
This is what you guys are talking about
Here, I took a pic for people that needed it:
More pics at http://www.cardomain.com/id/packetattack
I've been having trouble with this latch, i pull it up so that the door button works, and when i shut the trunk the button works for the first time but every time i shut my trunk the button just goes right back down. How can i fix this? is this normal, do i have to keep pulling up the button after everytime i open the trunk??
Originally posted by Maximus90
Hey Craig,
Hey Craig,
it shouldn't be doing that, you could probably just prop it up or something though, maybe even just use a rubber band or something to hold it in teh right place
REDinLV
Aug 15, 2024 12:30 AM
mrgooch
Sep 21, 2015 08:43 PM
rbaker100
Sep 6, 2015 02:46 PM
