Front strut bar and rear sway bar worth it?
Just wondering if its worth 200 bucks to get a front strut bar and a rear sway bar even if I don't plan on lowering my car and Im going to keep the stock wheels too. Will I notice a difference with just the front struts. Thanks.
RSB will dramatically increase your car's handling capability and FSTB should increase its rigidity.
Do it. You WILL notice a difference.
That said, it's not like at $200 you're getting a bargain, unless we're talking Stillen RSB or a name-brand FSTB.
$200? I paid something like $25 for my front bar on ebay. The thing was dirt cheap. It works fine and looks good. Maybe you can find a better price than $200 for both. It sounds like I need a rear bar for Christmas.
Just got my RSB installed over the weekend, and I must say, the back end is so firm that it swings out now on sharp corners, whereas before, I felt like I was going to be thrown off my seat. Definitely a useful mod for our boats!
hopefully i am getting my RSB for x-mas...like said before u can pick up a FSTB for liek 25 bux..i bought one form ebay...but from what i hear and i have drivin other 4th gens with RSB its def a must mod even of ur not lowered......as far a Sub-Frames.....they focourse will increase the rigidity of the frame and if ur lowered u will feel an vast improvement in ride quality
And because I know someone will ask, the RSBs are for years 95-03 so you can use one off a 5th Gen as well.
Originally Posted by speed racer
So who makes these subframe connectors? And when you mean that the car will feel more ridid, does that imply that you can make turns faster without roll?
Originally Posted by MorpheusZero
No, it means there will be less chassis flex. You should have the same amount of body roll but your car will feel more solid through turns, since it isn't twisting and contorting as much.
http://forums.maxima.org/showthread....highlight=sfcs
Plenty of threads out there still too, you should make use of that search function...
definately worth it.
I just put a cattman RSB on my 99 and the difference is incredible. I have no other suspension mods. The car still has a really cush ride, but when I swing it into a corner, I don't feel lik I am driving a bowl of mashed potatos any more. Granted, w/o other mods, it won't be handling like you friendly neighbor hood BMW, but it is definatly worth the investment.
For the price, I think the RSB is the best singular mod you can do. It really improves on the (IMHO) weakest part of our cars. I noticed an instant difference. It almost felt as if the center of gravity on the car went from the roof to seat-level.
I paid $100 shipped for a used RSB on the org, and around $30 for a FSTB on ebay.
As far as RSBs are concerned, you guys would suggest investing in a more expensive bar than just getting some cheap thing off ebay, right? I generally find that ebay "brand name"
car parts are inferior in quality.
Originally Posted by 98maximagle
when the quality ones (addco, progress) are so inexpensive, why get a potentially lower quality one?
I've got a Stillen FTSB but have heard that an RTSB doesn't do that much more for handling - is that wrong?
A bit off-topic but has anyone experienced oversteer with badly tuned stabiliser bars?
both are a must-have. also consider the subframes and the little-known lower-tie bar. it links the bottom of the front suspension to sharpen up turn it and improve handling.
kingw323
20
Oct 21, 2015 08:36 AM
MaxStock
Aug 14, 2015 10:03 PM
