1999 SE-Limited issues?
Old Dec 13, 2005 | 07:55 AM
maximabebe's Avatar
I am currently in the market for a 99 SE-L 5 speed maxima. If I recall correctly, there were some issues/problems that pertained particularly to the 99's. The vehicle I have found (and may possibly buy) is a federal U.S. spec 5 spd. 99 SE-L. Were there any emissions issues or anything else I should look out for upon this purchase? By the way, it's a lovely color called crimson blaze. =)
Old Dec 13, 2005 | 07:59 AM
NmexMAX's Avatar
dot dot dot ...
Coil packs typically go bad in multiple quantities.
Old Dec 13, 2005 | 08:00 AM
tavarish's Avatar
fwd gone rwd cr00
hmm...i thought all 99's were cali-specs..
for 99's, you should look out for their faulty coil packs. The car also has less power than the rest of the 4th gens, because it has more emissions related equipment, and it's also heavier. Crimson Blaze is an awesome color.
-Freddy
Old Dec 13, 2005 | 08:07 AM
Zack342's Avatar
-Freddy
Wrong Wrong Wrong......Show me where you can prove any 1999 Calispec car has less power than fed spec cars?
If anything you will make more power once you start doing mods.
My car makes
201whp with just
Popcharger
Y-pipe
Exhaust
MEVI
UDP
Ground Wires
And stock ECU
Old Dec 13, 2005 | 08:38 AM
MaximaSE96's Avatar
Maxima Owner
yea what he said
Old Dec 13, 2005 | 08:53 AM
NmexMAX's Avatar
dot dot dot ...
-Freddy
Speaking out of as.s. much? Proof ownz you. As far as I'm concerned .... what you say about power might be opposite ...
My car makes
201whp with just
Popcharger
Y-pipe
Exhaust
MEVI
UDP
Ground Wires
And stock ECU
Old Dec 13, 2005 | 09:30 AM
maximabebe's Avatar
so why do the coil packs act up in the 99's moreso than the other 4th gens?
Old Dec 13, 2005 | 09:36 AM
MaximaSE96's Avatar
Maxima Owner
Nissan got a faulty batch from the company who makes them
Old Dec 13, 2005 | 10:04 AM
rdbaron9's Avatar
What are the symptoms of a bad coil pack? I just bought a 99 SE 5spd about a year ago. Now the CEL is on and it quits randomly when I am coming to a stop with my foot on the brake and clutch. I thought it was probably the IAC since it has about 110k miles on it? would bad coils cause this? were there any recalls for the coils?
Old Dec 13, 2005 | 10:06 AM
NmexMAX's Avatar
dot dot dot ...
If it feels like a misfire, then that's your problem (coil).. Sounds more like a MAF/ECTS issue.
Old Dec 13, 2005 | 10:23 AM
Nismo3112's Avatar
Custom User Title
My 99 SE-L was a fed spec...
63k on it so far and it has shown no signs of bad coil packs.
The only problem I had on that car was an oil leak at the oil pressure sensor, which was fixed for $6.
Old Dec 13, 2005 | 10:26 AM
NmexMAX's Avatar
dot dot dot ...
So we're turing this into one of those threads...
Just had 2 CP's go bad on a friends 99 this past weekend. 74k.
Old Dec 13, 2005 | 10:39 AM
tavarish's Avatar
fwd gone rwd cr00
let me correct myself. i've driven a few 99's and they FELT to be slower than my '98. That could be for a variety of reasons. I thought that more emissions equipment meant less power, due to more restriction. If you have a 99 and it makes more than 200whp, great, you proved me wrong.
Old Dec 13, 2005 | 10:42 AM
NmexMAX's Avatar
dot dot dot ...
No dyno or timeslip, no care..
Zack just did ...
Old Dec 13, 2005 | 10:48 AM
njmaxseltd's Avatar
I had to replace all the coil packs on my 99 just as it hit 100,000 miles. No big deal, really, all else seems perfect - a very reliable car. Your lucky if you get a fed spec. You wount have the restrictive swish valve intake manifold and related emissions controls. That also gives you the option of a better Y pipe for your 99 which is the best bang for the buck power maker for our cars. The Crimison Blaze color only available on 99 SE-L's plus the fact that it's a 5 speed fed spec make that a very rare car.
Good luck with your purchase.
Old Dec 13, 2005 | 10:50 AM
tavarish's Avatar
fwd gone rwd cr00
Zack just did ...
that part of the post was directed towards him, as he just stated he had 201whp. I based my view on my experiences and speculation, but it proved to be incorrect.
Old Dec 13, 2005 | 12:10 PM
gx2nds4's Avatar
what about 1998 and 1997 issues I've read that there are some problems with the 1997. Is the 1998 the best 97+ 4th gen to go for? sorry for thread hijack but it's sort of pertaining to the topic
Old Dec 13, 2005 | 02:05 PM
Northern Maxima's Avatar
Buy it!!! Its rare! Is the interior black or beige? I haven't had any problems with my 99 yet but the mileage is still pretty low. IMO coil packs aren't a big enough problem to not consider a 99.
Old Dec 13, 2005 | 02:12 PM
NmexMAX's Avatar
dot dot dot ...
I vote because I've never heard of any unusual year specific problems with th 97...And of course the thread hijack
95/6 starter
96 O2 sensors
99 coils.
Old Dec 13, 2005 | 03:21 PM
99MAXSE-L's Avatar
I have a 99SE-L and im getting bad coils now....
Old Dec 13, 2005 | 06:07 PM
gx2nds4's Avatar
95/6 starter
96 O2 sensors
99 coils.
Automatic transmission: The original automatic-transmission (model F04) shift solenoids allowed slipping and premature wear. (1997)
Engine knock: Spark knock or ping may result from a defective onboard computer. (1995-97)
Rough idle: Several problems (no-start, no A/C, rough running, etc.) can be traced to broken wires in the engine compartment where the harness bends near the right strut tower. (1995-97)
Rough idle: Rough running engine accompanied by check engine light may require revised powertrain control module. (1997)
source: http://auto.consumerguide.com/Auto/U...ewreliability/
I dont know, I'm looking at getting either a 97 or 98 black SE. Of course I have to thread hijack. As a noob I how would I reply to to these topics seeing as I obviously know less than you guys. If I can't contribute anything new/valid I won't post and essentially won't be able to make a thread.
Old Dec 13, 2005 | 08:36 PM
tavarish's Avatar
fwd gone rwd cr00
don't forget the 98 alternator.
Old Dec 15, 2005 | 03:47 PM
vkarasik's Avatar
Coil Problem?
I just got the SEL P0300 (Multi Cyl Misfire) on my 99 maxima with 60K miles on it. The car really misfires on idle. Is this a coil issue?
vk
Old Dec 15, 2005 | 03:50 PM
NmexMAX's Avatar
dot dot dot ...
More than likely...yes
Old Dec 15, 2005 | 03:51 PM
Digital's Avatar
VIP
Sweet dude! Crimson SE-L! So rare! instant hotness!
Old Dec 16, 2005 | 03:23 PM
leomax's Avatar
i would buy it only for the color. any other problem is fixable
Old Dec 16, 2005 | 03:35 PM
leomax's Avatar
Old Dec 16, 2005 | 03:42 PM
rdbaron9's Avatar
Everyone keeps mentioning how good this color is, does anyone own one of this color that has some pics. They must be really rare because I haven't seen a color that sounds like crimson on any maximas around here.
Old Dec 16, 2005 | 05:05 PM
If you check out my Car Domain page: http://www.cardomain.com/id/tbaymax I have a few pics of BlueC's Crimson Blaze Max from a couple different meets if you scroll down. Its really an awesome color IMO and not a whole lot of them were made.
Old Jan 9, 2006 | 07:54 AM
maximabebe's Avatar
Marc I just bought it I'm so f##kin excited! ya gotta see her! BTW I grabbed a 99 se-l crimson blaze 5 spd Cali-spec. I'm in love!
Old Jan 9, 2006 | 04:20 PM
Does that Crimson Blaze have a black or tan interior? Even more rare if its black...now that would be the perfect 4th gen IMO!
Old Jan 10, 2006 | 07:45 AM
maximabebe's Avatar
black leather ... yummy
Old Jan 10, 2006 | 03:51 PM
I'M SO JEALOUS!!!! Many congrats on the purchase
Be sure to post some pics for us to drool over!
Old Jan 10, 2006 | 08:50 PM
gx2nds4's Avatar
how much does it cost to replace the faulty ignition coils?
Old Jan 11, 2006 | 01:29 PM
Phaedrus220's Avatar
100 posts/7 years - woot!
congrats on joining the SE-L club. Since I've had mine, aside from maintenance I've replaced the rear 3 coils (got used 97 coils cheap), and just replaced the rear calipers (driver side froze w/winter, known prob for 4th gens).
My cali spec screams w/the mods I have, no complaints, 130k. The SE-L steering wheel rules over the gxe version.
Old Jan 17, 2006 | 07:32 PM
Thahman's Avatar
Here in Cali, it's a cop catcher, too risky.. :-P
Old Jan 17, 2006 | 07:46 PM
BlueC's Avatar
wat
Where you were wrong is that not all '99s are Cali-spec. I have a SE-Limited and its federal spec just like every other maxima on the road. Not to mention, I find it in no way slower than the previous models. No extra emissions equipment, no different than a '98 (Other than the perforated leather, TCS, sexy red color, etc).
Old Jan 18, 2006 | 01:59 PM
max2di4's Avatar
My Cali-spec SEL runs just as great as the Fed spec. She is 5 speed with black leather. Everyone thinks I painted it red even the guys at the dealer. One guy when as far as checking the paint code.
Check out some of my pics http://www.cardomain.com/ride/807398.
Old Jan 18, 2006 | 02:07 PM
NmexMAX's Avatar
dot dot dot ...
Crimson Blaze FTW.
Old Jan 18, 2006 | 02:46 PM
crazy1eye's Avatar
Pardon me, but whats the diff between an SE & an SE-L?
