to those who have taken out the clock/vent assembly
After installling a stereo in my car, the clock/vent piece never sat perfectly flush. I have a few milimeters of space between the main panel and the vent/clock piece. When putting the assembly back in, i have simply pushed it straight in and it locks into place. Is there a specific way to get it back in to eliminate the gap? It seems that Since I devirginized the factory seal that i may have the gap forever, if thats the case, its no big deal, but is there a way to eliminate it? Thanks
On the bottom of the piece there are 2 tabs that lock into the frame of the dash, check those and see if they are bent inward. I had to rebend mine back out so that the tabs would lock back into the hole.
Originally Posted by 4x4Max
dude it takes like 30 seconds to take apart the console/dash peices, including the screws, it cant be a PITA
Originally Posted by Fr33way
It's a PITA because it is all thin plastic and that can be nerveracking.
agreed. i hate messing around with my dash more than i have to. removing that panel by the driver's knees once for a gauge bezel install was bad enough, but then again for gauge rings!?!? let's just say it's seen better days. those clips are indeed a PITA
EDIT: and yes, i removed my clock assembly and it does stick out just a mm or two.
James92SE
142
Jan 2, 2024 09:23 AM
atriuum
Sep 28, 2015 01:19 PM
MannyMonroe
Sep 17, 2015 02:34 PM
