For those of you with '00VI please read
Old Dec 22, 2005 | 12:36 PM
1NICEMAX's Avatar
I just got my car back. Have idling problems. I have to push the gas at engine start-up in order to prevent it from stalling. Have you guys had this problem and know a solution?
And I didn't check my rpm switch yet but am I only supposed to feel the power of the VI when it reaches the desired rpm?
Old Dec 22, 2005 | 01:11 PM
Tatanko's Avatar
Bacon Lover
It was always my understanding that the 00VI had small gains throughout the whole RPM range
Old Dec 22, 2005 | 02:52 PM
lilaclucymaxima's Avatar
Team Ramrod
yessum.
Old Dec 22, 2005 | 03:10 PM
s0ber's Avatar
Be more specific, what exactly did you do? What setup, do you have your IACV hooked up? ETC ETC...
You're not going to feel jack, there is not NAWZ like power boost if thats what your expecting when the VI opens.
Old Dec 22, 2005 | 07:35 PM
nismology's Avatar
Can you hear any vacuum leaks? Is the TPS adjustment within spec?
Old Dec 23, 2005 | 02:42 AM
Ceasars Chariot's Avatar
Old Maxima Legend
suggest to move this to all motor where the VQ wrench crew hangs out !
Old Dec 23, 2005 | 05:44 PM
cantcatchme's Avatar
just check how much air is bypassing ur tb, when i first made my iacv it did the same thing cuz i used too small of tubing, then i stepped it up , now idles perfect, just my suggestion
Old Dec 28, 2005 | 01:27 PM
MaXaZoR's Avatar
I had the same problem on cold starts it would rev up then drop and stall until it was warmed up and I don't have a 00vi...I cleaned out my throttle body and it went away...Im not sure if this is the same problem.
Old Dec 29, 2005 | 01:21 AM
give_me_bud's Avatar
i had a similar problem but it was a simple fix. my problem was just a stupid hose not hooked up to the intake
mclasser
22
Nov 12, 2020 01:58 PM
chisam14
Nov 6, 2018 08:56 PM
mkaresh
Mar 12, 2018 06:48 PM
maxinout93
Oct 31, 2015 02:04 AM
