Stupid Oil change question
Old Dec 30, 2005 | 06:06 PM
thisasian's Avatar
I'm stupid and picked up the wrong oil filter, I think. It was pretty small, like 2.5" dia x 2.75" long. I put it on anyway, b/c I already drained the oil and mutilated the old filter trying to get it off. So, will it hurt my engine to leave it on 'til the next 3k? or should I take it off pretty soon and change my oil agian w/ the right filter?
Old Dec 30, 2005 | 06:09 PM
Puppetmaster's Avatar
What was the part number?
Old Dec 30, 2005 | 06:49 PM
MDeezy's Avatar
Seems like your already driving with the oil filter. . . there goes the chances of a return.
I would still get the right filter.
Old Dec 30, 2005 | 08:07 PM
thisasian's Avatar
it was an stp filter, 6607 i think
Old Dec 30, 2005 | 08:47 PM
konak85's Avatar
Get the right filter soon. might cost you thousands if something goes wrong
Old Dec 30, 2005 | 09:08 PM
White Shadow's Avatar
Still chugging along...
I have done the same ting before. I got the application for my '92 Stanza instead of the '96 Maxima while in the store - brain fart. I also discarded the old one before I realized the new one was wrong. I put it ona and figured it couldn't hurt if I changed it back soon. It ended up being about a week and a half before I changed it to the right one. I had no problems whatsoever. You'll be fine. That engine lasted for 167K before my wife blew it by running it hot (no coolant at all in the radiator = bad) for a long period. But Now I have a complete '97 engine that only had about 60K miles when I got it. I love the salvage yard.
Old Dec 31, 2005 | 12:18 PM
njmaxseltd's Avatar
Don't assume it's the wrong filter because it's a different size then the old filter you took off the car. Filter sizes do vary from different mfg.'s.
Old Dec 31, 2005 | 12:53 PM
Weimar Ben's Avatar
Helicopters! Money!!!
lol, the oil filter for the 2000-2001 maxima is the same oil filter used for a CBR600. You'll prolly be fine, but if it makes you feel better, go get a different filter.
Old Dec 31, 2005 | 04:38 PM
carsarecool's Avatar
At autozone we sell the 6607 STP, its the right filter so dont worry, it is short though. ive had people ask me about that a lot, it only has to do with the amount of oil that flows through it. Its the same size as fram(not that id use fram) if you want a better and longer filter get the Bosch 3323 for 5.99 or Mobil 1 filter but their like 10.99, but for now your fine, 6607 is correct.
Old Jan 1, 2006 | 09:18 AM
Bobo's Avatar
Change the oil filter, but there is no need to change the oil, simply top it up if necessary.
Stick with the Nissan OEM filter, or alterntatively Purolator PureOne, WIX or Napa Gold.
Old Jan 2, 2006 | 09:08 AM
thisasian's Avatar
Filter only?
Didn't know you could change the filter w/o all the oil dumping out.
Normally I'd use the OEM, but STP works for now.
Glad to know that was the right filter.
Thanks for all the input.
Old Jan 2, 2006 | 09:11 AM
dannydoo's Avatar
i would just get the right one and be done wit the worrying
Old Jan 2, 2006 | 09:14 AM
Ammi's Avatar
350 Detroit Muscle
You should be fine until your next oil change
Old Jan 2, 2006 | 09:49 AM
Weimar Ben's Avatar
the STP, Pennzoil, and Fram filters are all the same. Don't use them.
Old Jan 2, 2006 | 09:58 AM
Ammi's Avatar
350 Detroit Muscle
Fram might not filter as good as other filters but it still does its job. I've been using nothing but Fram (love that rubber grip) on my 2000 civic. After 250k miles on it, car still runs strong.
Old Jan 2, 2006 | 12:54 PM
Teufelhunden's Avatar
fram is good. i used them on my 240 for about 4 years with 190k on it. i sold the car but it still ran good, as long as its not a no brand name, like the gas station uses.
Old Jan 2, 2006 | 04:34 PM
Weimar Ben's Avatar
wrong.
http://minimopar.knizefamily.net/oilfilters.html
"Years ago Fram was a quality filter manufacturer. Now their standard filter (the radioactive-orange cans) is one of the worst out there. It features cardboard end caps for the filter element that are glued in place. The rubber anti-drainback valve seals against the cardboard and frequently leaks, causing dirty oil to drain back into the pan. The bypass valves are plastic and are sometimes not molded correctly, which allows them to leak all the time. The stamped-metal threaded end is weakly constructed and it has smaller and fewer oil inlet holes, which may restrict flow. I had one of these filters fail in my previous car. The filter element collapsed and bits of filter and glue were circulating through my system. The oil passage to the head became blocked and the head got so hot from oil starvation that it actually melted the vacuum lines connected to it as well as the wires near it."
Old Jan 2, 2006 | 05:22 PM
not so much here but on a Grand am site a lot of members had problems with fram filters breaking up inside- STP ive heard is better, that site says its a champion labs filter, along with bosch, even though bosch is a lot more $$. we dont sell pennzoil filters.
Old Jan 4, 2006 | 07:52 PM
thisasian's Avatar
I heard that the 300zx filter will fit. I think I might use that for my next oil change.
Old Jan 5, 2006 | 03:08 AM
panda_1's Avatar
then what is a good oil filter to use for the max, after oem of course? ive been using the mobil 1 for a while and i think i like it!
heres another question, the owners manual says to put in 4 1/4 quarts of oil, but when i check the oil on the dip stick after its alwayz low, why is that? this might be a stupid question but im curious.
Old Jan 5, 2006 | 11:13 AM
Ammi's Avatar
350 Detroit Muscle
Mobil1 is a good choice but OEM is half the cost. I have to put 4 1/2 qts in my car.
Old Jan 5, 2006 | 03:42 PM
panda_1's Avatar
what about the k&n filters? isnt their filters a bit bigger than normal? dont they also let you put in a bit more oil?
Old Jan 5, 2006 | 08:31 PM
vansskaterfreek's Avatar
i have been using the cheap fram filter..... after i read this it makes me want to **** on it.. now i am going with the V8 toyota filter.. i have heard good stuff with that.. im not sure if it will fit anything else besides a 1989-1994 maxima
Old Jan 5, 2006 | 08:32 PM
Tenn05's Avatar
I've used the Fram filters for a while on my 95' Nissan P/U from the time i bought it, 35,000 miles to 181,000 now. Also started using them on my 98' Maxima SE when i bought it, 96,000 to 170,000 now, but i did change to the Tough Guard line of the Fram filters for the one excepitional reason,,,, the Anti-Drain back design. The Maxima always, ( More during cold weather), had a slight and very quick rattle at first start up. I talked to a former Nissan repair tech. and that is what he reccomended was one of the new type oil filters with the Anti-Drain back design. IT CURED THE START UP RATTLE!!!
Is Fram the better filter?????? My bro. had a Chevy Spectrum Turbo that blowed a fram filter apart, and you couldn't give him a lifetime supply of them, so it's your own choice.
Old Jan 9, 2006 | 11:57 PM
panda_1's Avatar
which toyota filter is that and does it fit the 5th gens?
on another note, how do you know if a filter has the anti drain back? would it specify on the back?
kmitchel
Oct 30, 2016 05:28 PM
MatthewsMaxima
Sep 11, 2015 03:21 AM
tnewbs
Aug 28, 2015 10:15 AM
maxinout93
Aug 20, 2015 02:17 AM
