Subframe aka Suspension Member installation?
How hard is it to remove and install the Subframe/suspension member on a 2k2 max? I took a look under the car and I see the engine cross member, two control arms, and a few other bolts that hold this suspension member in place....is there anything else that I'm missing? I also took note that the bolts holding the suspension member to the frame, is torqued quite high...some upwards of 100ft-lbs....and so are the control arm bolts
I don't have access to a lift and don't have air tools...if I do the install, it will be done with hand tools and an 18.75 inch 1/2 drive breaker bar...can someone tell me if this is a DIY installation? Thanks
Originally Posted by rbrown81
Unless of course Im thinking of the wrong thing...
Ah crap I think I am.
I already know how to remove the engine cross member anyway...its a breeze
Originally Posted by scopium
WTF did you do now? Dude seriously, you need to stop working on your car. Leave it to a qualified mechanic. I heard you bought the same supension bolt like 3 times in a row at the dealership!
I would recommend at least a impact wrench, those suspension bolts are very tight.
Take a look at the FSM to see exactly what you need to remove in the process. There are only four bolts holding the subframe up.
MaxLife17
Jun 27, 2019 01:37 PM
