Unresloved front suspension noises? Step right in.
Old Jan 23, 2006 | 09:44 AM
kobalt's Avatar
Do you have front suspension clunking/banging noises consistant with bad stabilizer links or struts? While these parts may be at fault, check the strut top hat first. The top hat has a small notch that is labeled "out" on top. Make sure that the notch is aligned with the two bottom strut mounting bolts. In my case both the struts and the links turned out ok but the top hat was about 45 degrees out of alignment on one side and completly opposite on the other. No more clunking/groaning sounds!
Old Jan 23, 2006 | 10:50 AM
MaxKlinger's Avatar
Good to know, thanks for the tip! The struts are shot on my dad's 02SE, going to be geting struts (Tokico Illuminas) and springs (H&R) this week, hopefully. I'll keep it in mind for installation.
Old Jan 23, 2006 | 02:15 PM
OOmaxSE's Avatar
Actually, I'm having horrible banging and clunking from my front suspension. I have KYB and Progress. It feels as though the springs are not compressed enough, almost like a completely loose set up. It's very unstable and while going over a series a little bumps, it feels like it's wiggling and shifting. Everything is torqued up to spec. Top hat is correct. Only thing I can really think of is possibly the top hats are on the opposite sides of where they should be? Another possibility could be that something is worn out, strut mount/space/etc...
I mind as well resolve this problem and throw on some coilovers.
Old Jan 23, 2006 | 02:52 PM
Deckdout2's Avatar
Play with my balls
Me too, I have these issues. I'm changing to s-techs tomorrow, and hopefully will come to a conclusion to the problem.
Old Jan 23, 2006 | 03:00 PM
OOmaxSE's Avatar
What are you on now Deckdout2?
Old Jan 23, 2006 | 03:01 PM
Deckdout2's Avatar
Play with my balls
Illuminas and Progress. Going to Illuminas and S-Techs
Matt93SE
May 24, 2019 02:58 PM
boomerbrian
Nov 8, 2015 05:10 PM
maxinout93
Oct 27, 2015 01:29 PM
official_style
Aug 29, 2015 10:10 AM
kirkhilles
Aug 8, 2015 10:53 AM
