Sponsored by:
Sponsored by: CARiD
Any opinions on this ebay FPR?
Old Feb 8, 2006 | 10:49 AM
Fred Allen Burge's Avatar
Hey,
Shopping for an adjustable fuel pressure regulator w/guage for my project. Anybody have any thoughts on this one:
http://cgi.ebay.com/ebaymotors/FPR-U...36521421QQrdZ1
It's the cheapest I have seen, wonder if it's worth messing with. Anybody using one of these on their 3.5L swap?
allen
Old Feb 8, 2006 | 11:36 AM
Donald199's Avatar
I am the warehouse guy there and they work just fine, the only time a customer complain is when he installed it backward LOL
Old Feb 8, 2006 | 11:45 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
i bought one and i have had no issues. only thing i did not care for was the yellow vacuum line. and yes i am too lazy to go to the parts store for that.
Old Feb 8, 2006 | 11:58 AM
Thanks guys!
allen
Old Feb 8, 2006 | 05:24 PM
diymaximakid's Avatar
whats the the psi range on the fpr
Old Feb 8, 2006 | 06:43 PM
96sleeper's Avatar
I have it, it works fine.
Old Feb 8, 2006 | 07:22 PM
nismology's Avatar
I see other adjustable FPR's for sale on e-bay. Is this the only one that's worthwhile? And also, does it come with that gauge that's in the picture?
Old Feb 8, 2006 | 07:48 PM
JamesNH's Avatar
my friend just got that for his miata ill let you know in a couple days if it leaks.
Old Feb 8, 2006 | 10:20 PM
Donald199's Avatar
It does come with the gauge and never heard of any leakage
But i would really recommand you guys to get some "decent" fuel hoses instead of using the one the came with the kit.
Old Feb 15, 2006 | 05:21 AM
Got the FPR yesterday. Everything looks okay, the hardware and guage feel kinda cheap but the regulator itself seems fine, should do it's job.
What's the best way to adjust this thing before I install it? I figured I could just run compressed air into the feed side and adjust to the proper pressure. I wouldn't need to do anything to the outlet side while doing this would I?
Thanks,
allen
Old Feb 15, 2006 | 07:15 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Allen,
Can you test whether it holds a 1:1 ratio, since I've heard some don't...not sure about this one though.
Old Feb 16, 2006 | 12:47 AM
Donald199's Avatar
they are all 1:1s. not a raising rate.
Old Feb 16, 2006 | 05:11 AM
nismology's Avatar
He knows they're supposed to be 1:1 obviously but he's wondering if it's less than 1:1 in actuality due to poor design and/or craftsmanship.
Old Feb 16, 2006 | 06:09 AM
Originally Posted by IceY2K1
Allen,
I'd be glad to test this thing in any way you need, just need some advice on how exactly to do that!
allen
Old Feb 16, 2006 | 09:11 AM
IceY2K1's Avatar
On an idling engine, you just use a brake bleeder or similar reversed and hooked to the vacuum port to apply positive pressure. Pump the bleeder to 10psi and if you know the base fuel pressure at WOT is 43psi, you should see 43+10=53psi of fuel pressure. If it's less, it's <1:1, if it's higher, it's >1:1.
Not sure how otherwise, but I'm sure someone here knows.
allen
Old Mar 3, 2006 | 07:48 AM
FYI, all you have to do to set the pressure before you install one of these is blow compressed air into the side port and watch the guage, mine came set at 40psi. So, as the air was blowing through it I adjusted the screw until it was at about 50psi then screwed the lock nut down tight.
allen
REDinLV
Aug 15, 2024 12:30 AM
litch
123
Jan 4, 2024 07:01 PM
magiconthetire
Oct 26, 2015 09:03 PM
220k+ A32
25
Oct 3, 2015 09:09 PM
soybeanz
Sep 25, 2015 10:46 AM
