energy suspension motor mounts, automatic
Old Feb 9, 2006 | 07:51 PM
i30krab's Avatar
We tried to install the new motor mount inserts but only the rear
one fit, the forward mount takes a larger insert!
Has anyone else encountered this problem?
If so, what's the fix??
Everything is always a hassle!!
Old Feb 9, 2006 | 07:56 PM
s0ber's Avatar
you need a front 5spd mount unfortunately im going through the same crap.
Old Feb 9, 2006 | 07:59 PM
i30krab's Avatar
I'm confused, do you mean there are different mounts for different standard trannies?? If so, what year are you talking about??
Old Feb 9, 2006 | 08:01 PM
s0ber's Avatar
I thought you said you had automatic? The ES motor mount inserts are only for 5spds...
Auto's bring a different front mount, electronically controlled mumbo jumbo crap...
Old Feb 9, 2006 | 08:09 PM
i30krab's Avatar
I do have an auto! Lets start over. Did you install the rear 5 speed mount in your auto tranny car? And if so, what if anything is available for the front mount?
Does anyone know about a substitute insert?
By the way, my rear motor mount was broken up and in bad shape. The front mount seems undamaged. It appears the rear mount takes most of the punishment.
Old Feb 9, 2006 | 08:14 PM
s0ber's Avatar
Ok since you have an auto, you either need to one.. Just replace the front mount with a new OEM if its bad, or 2) Find a used 5spd front mount and press in the ES inserts that you bought... The rear mounts on the autos and the 5-speed's are the same..
The ES bushings will not work in a front automatic mount..
I havnt replaced my mounts yet, I just did some research before I ordered the ES inserts..
Old Feb 9, 2006 | 09:19 PM
i30ds's Avatar
Armed and Dangerous
There was one guy that got the ES mount to fit in his front auto mount. He had to cut some metal and bend it and then press it into the mount housing so the insert would then properly fit.
Maxima_Joe's Avatar
4th Gen Parts King
The gxe auto mount is also the same 3" dia as the five speed mounts
Old Feb 9, 2006 | 09:22 PM
i30ds's Avatar
Armed and Dangerous
Right, its only the GLEs and the auto I30 boys.
Old Feb 9, 2006 | 09:23 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
Good info!
I30krab-I see in your profile, you're NA?
I thought you were still in the Air-to-Water crowd?
Old Feb 9, 2006 | 09:47 PM
i30krab's Avatar
[QUOTE=slimer]Good info!
I thought you were still in the Air-to-Water crowd?[/QUOT
Huh?
Old Feb 9, 2006 | 09:54 PM
slimer's Avatar
Did you take all of that work out of your car or am I just conjuring up crazy shiet?
Old Feb 9, 2006 | 10:18 PM
i30krab's Avatar
am I just conjuring up crazy shiet? Yes you are!! Everything is all there including SC and N2O.
:attention
Old Feb 9, 2006 | 10:34 PM
slimer's Avatar
then why is (NA) next to your car description?
Old Feb 10, 2006 | 05:49 AM
s0ber's Avatar
Im assuming its the auto I30's, GLE's and some auto SE's as well..
Old Feb 10, 2006 | 06:19 AM
|Bijan|'s Avatar
UCF Lexus
NA = not appilcable (for trim of car) since he didnt put the letter "t" in that spot.
Old Feb 10, 2006 | 06:28 AM
i30krab's Avatar
Hi guys! I think I fixed it and got rid of the n/a
Please bear with me one more time on this motor mount crap!!
You're saying that this mount is a front 3" mount that will bolt right up to my car so I can use the front ES insert??
A7000-128800
Nissan Maxima 3.0 GXE
Brand: Engine Mount
Fits Engine - Chassis:
VQ30DE — A32
And do I need this?
Product Brand List Price Core Ships
A7150-128802 Engine Mount Stop 14.51 $9.36
Old Feb 10, 2006 | 12:35 PM
i30krab's Avatar
I found a place called ABC nissan in phoenix AZ and they have a front motor mount for the 1996 Nissan Maxima 3.0 GXE- Fits Engine - Chassis:VQ30DE — A32
part # 1127040-U02.
The guy took it out of stock and measured and it is 3 1/2" diameter. It also cross references to the 96 I30 infiniti stick shift.
He claims it should bolt right up to an automatic frame.
Has anyone here used this mount on the max or i30 automatic??
This would solve the problem for people with automatic trannies wanting to use the energy suspension inserts.
Am I missing something?,,Has anyone here successfully done this??
Old Feb 10, 2006 | 12:41 PM
cardana24's Avatar
Blown
just another idea. You can return your front motor mount insert, and then just fill the front one with poly urethane. I filled the mounts on my 95 GXE and they are holding up fine. Just another option, if you cannot figure out the ES front bushing.
Old Feb 10, 2006 | 12:47 PM
i30krab's Avatar
How long does it take to dry after it's poured?. Can you bake it in an oven?
Old Feb 10, 2006 | 01:14 PM
cardana24's Avatar
Blown
I don't know about baking...If I recall you are suposed to let it set up for three days. I know when I did mine I let them set up for 6 days because I had the engine out of the car, so I did not have a need to put mine back in until I dropped the new engine in. I got the stuff from mcmaster carr, I believe is was shore 80, if you search "filling motor mounts" either here or the general discussion, the link to the poly urethane is posted.
Old Feb 10, 2006 | 07:30 PM
i30krab's Avatar
part # 1127040-U02.
BUMP BUMP THUMP
Old Feb 11, 2006 | 10:23 AM
i30krab's Avatar
You need a front mount that is 3" in dia The electronic controlled mounts are 3.5" in dia and thats what you have now.They are both the same mounts and bolt up directly the same way the only diffrence being the dia of them.I may have a 3" mount i will have to double check though. If you can't find one then let me know.
I thought the front electronic automatic motor mount measures 4" diameter!!
The ES inserts measure 3.5".
Am I right or wrong??
Old Feb 11, 2006 | 02:44 PM
nismos14's Avatar
§è~® f®ÈÄk
It might measure 3.5 but its gotta be pressed in and will contract a little bit I think.
Old Feb 11, 2006 | 05:12 PM
Maxima_Joe's Avatar
4th Gen Parts King
Sorry Yes the electronic mount is 4" and you need the 3.5" I don't know what i was thinking. I will edit my post for the correct info.
Old Feb 11, 2006 | 05:14 PM
Maxima_Joe's Avatar
4th Gen Parts King
part # 1127040-U02.
This mount will work for you. Whats the price on it?
Old Feb 11, 2006 | 05:37 PM
i30krab's Avatar
The price is $ 72.70 plus shipping.
Most places were $15-20 more!
By the way, how do you like the picture of my mother-in-law when she was younger???
Old Feb 11, 2006 | 05:43 PM
Maxima_Joe's Avatar
4th Gen Parts King
That is damn expensive. Escpecially since your not even gonna use the mount.
The picture is disturbing.
Old Feb 11, 2006 | 05:48 PM
i30krab's Avatar
Sometimes you have to pay to play!!
Here is my sister-in-law and brther-in-law
Old Mar 23, 2011 | 12:26 AM
ef9's Avatar
ef9
Isn't the Energy Suspension Inserts (part number 7.1114) only for the LEFT and RIGHT mounts?
I see you guys say the mounts can be used on the front and rear mounts.
Old Mar 23, 2011 | 06:52 AM
max ride 41's Avatar
ummmm, i think he figured it out seeing as this thread is 5 YEARS OLD
Old Mar 23, 2011 | 11:54 PM
ef9's Avatar
ef9
I knew the thread was old, but don't penalize me for using the SEARCH feature on this site. Amazon.com has the Energy Suspension Motor Mount inserts on their site, but it says "Left & Right" for the application.
I just want to confirm that they mounts are for front/rear as I have almost my entire engine bay taken apart to pieces.
Old Dec 14, 2011 | 07:29 PM
comingup's Avatar
Thanks for updating, I kinda need this info! I found front and side mounts from energy suspension but nothing for rear... I need to do this so I can slap in the y-pipe and pacesetter
Old Dec 14, 2011 | 10:18 PM
they dont make rear for our cars
Old Dec 14, 2011 | 10:44 PM
nitromax's Avatar
We tried to install the new motor mount inserts but only the rear one fit, the forward mount takes a larger insert!
this says the rear DID fit, the front was the issue. which seems to have been solved with a front GXE mount for auto from 96. rear= right side of engine, front= left side. then there is the mount on the right/passenger side of the car that is refered to as the right front mount (actual front of the engine).
Old Dec 15, 2011 | 01:18 AM
J2FRESH's Avatar
Old Dec 15, 2011 | 08:01 AM
comingup's Avatar
interesting...
Maximan190
Dec 16, 2015 06:01 AM
QueensMAX
Sep 15, 2015 04:14 AM
Violator
Sep 9, 2015 10:14 AM
