energy suspension motor mounts, automatic
![](https://maxima.org/forums/images/smilies/support.gif)
We tried to install the new motor mount inserts but only the rear
one fit, the forward mount takes a larger insert!
Has anyone else encountered this problem?
If so, what's the fix??
Everything is always a hassle!!
![nopity](https://maxima.org/forums/images/smilies/nopity.gif)
Originally Posted by s0ber
you need a front 5spd mount unfortunately im going through the same crap.
![rolling eyes](https://maxima.org/forums/images/smilies/rolling_eyes.gif)
![BangHead](https://maxima.org/forums/images/smilies/banghead.gif)
I thought you said you had automatic? The ES motor mount inserts are only for 5spds...
Auto's bring a different front mount, electronically controlled mumbo jumbo crap...
Does anyone know about a substitute insert?
By the way, my rear motor mount was broken up and in bad shape. The front mount seems undamaged. It appears the rear mount takes most of the punishment.
Ok since you have an auto, you either need to one.. Just replace the front mount with a new OEM if its bad, or 2) Find a used 5spd front mount and press in the ES inserts that you bought... The rear mounts on the autos and the 5-speed's are the same..
The ES bushings will not work in a front automatic mount..
I havnt replaced my mounts yet, I just did some research before I ordered the ES inserts..
There was one guy that got the ES mount to fit in his front auto mount. He had to cut some metal and bend it and then press it into the mount housing so the insert would then properly fit.
Originally Posted by fanaticrockford
The gxe auto mount is also the same 3" dia as the five speed mounts
![ThumbsUp](https://maxima.org/forums/images/smilies/thumbsup.gif)
I30krab-I see in your profile, you're NA?
![wtf](https://maxima.org/forums/images/smilies/wtf.gif)
I thought you were still in the Air-to-Water crowd?
Originally Posted by slimer
Did you take all of that work out of your car or am I just conjuring up crazy shiet?
![flower](https://maxima.org/forums/images/smilies/daisy.gif)
Hi guys! I think I fixed it and got rid of the n/a
Please bear with me one more time on this motor mount crap!!
You're saying that this mount is a front 3" mount that will bolt right up to my car so I can use the front ES insert??
A7000-128800
Nissan Maxima 3.0 GXE
Brand: Engine Mount
Fits Engine - Chassis:
VQ30DE — A32
And do I need this?
Product Brand List Price Core Ships
A7150-128802 Engine Mount Stop 14.51 $9.36
![naughty](https://maxima.org/forums/images/smilies/naughty.gif)
A7000-128800
Brand: Engine Mount
VQ30DE — A32
And do I need this?
![Confused](https://maxima.org/forums/images/smilies/confused.gif)
I found a place called ABC nissan in phoenix AZ and they have a front motor mount for the 1996 Nissan Maxima 3.0 GXE- Fits Engine - Chassis:VQ30DE — A32
part # 1127040-U02.
The guy took it out of stock and measured and it is 3 1/2" diameter. It also cross references to the 96 I30 infiniti stick shift.
He claims it should bolt right up to an automatic frame.
Has anyone here used this mount on the max or i30 automatic??
This would solve the problem for people with automatic trannies wanting to use the energy suspension inserts.
Am I missing something?,,Has anyone here successfully done this??
part # 1127040-U02.
just another idea. You can return your front motor mount insert, and then just fill the front one with poly urethane. I filled the mounts on my 95 GXE and they are holding up fine. Just another option, if you cannot figure out the ES front bushing.
Originally Posted by i30krab
How long does it take to dry after it's poured?. Can you bake it in an oven?
part # 1127040-U02.
part # 1127040-U02.
You need a front mount that is 3" in dia The electronic controlled mounts are 3.5" in dia and thats what you have now.They are both the same mounts and bolt up directly the same way the only diffrence being the dia of them.I may have a 3" mount i will have to double check though. If you can't find one then let me know.
The ES inserts measure 3.5".
Am I right or wrong??
![arty](https://maxima.org/forums/images/smilies/party2.gif)
I thought the front electronic automatic motor mount measures 4" diameter!!
part # 1127040-U02.
part # 1127040-U02.
This mount will work for you. Whats the price on it?
Most places were $15-20 more!
By the way, how do you like the picture of my mother-in-law when she was younger???
The price is $ 72.70 plus shipping.
The picture is disturbing.
That is damn expensive. Escpecially since your not even gonna use the mount.
![igor&donkey](https://maxima.org/forums/images/smilies/gayfight2.gif)
Here is my sister-in-law and brther-in-law
I knew the thread was old, but don't penalize me for using the SEARCH feature on this site. Amazon.com has the Energy Suspension Motor Mount inserts on their site, but it says "Left & Right" for the application.
I just want to confirm that they mounts are for front/rear as I have almost my entire engine bay taken apart to pieces.
this says the rear DID fit, the front was the issue. which seems to have been solved with a front GXE mount for auto from 96. rear= right side of engine, front= left side. then there is the mount on the right/passenger side of the car that is refered to as the right front mount (actual front of the engine).
QueensMAX
09-15-2015 04:14 AM
Violator
09-09-2015 10:14 AM
