Thumping Noise in Driveline problem
Old Feb 17, 2006 | 05:11 AM
Max_Gator's Avatar
I'm getting a thumping noise somewhere in the driveline. It is actually more something I can feel in the gas pedal. It is definitely speed sensitive.
It happens mainly when I accelerate slightly from a steady speed. For example, 3rd gear 2500 rpms and I'm just cruising at that speed when I slightly accelerate - I can then feel the thump in the gas pedal. If I accelerate hard - I don't feel it. I can also feel it at higher crusing speeds in 5th gear.
Just yesterday, I discovered that if I just let 2nd gear winddown without pushing in the clutch, I get the thump the worst. And it does feel like it is coming from the drivers side where the transmission is located.
Checked the tranny fluid - it's full. Did not drain and look for metal particles.
My first guess is that it is related to the tranny, but I guess it could be a CV or wheel bearing. It almost feels like the axle is slipping in the tranny.
Any thoughts? (101k on 2k)
Old Feb 18, 2006 | 09:38 AM
zoner's Avatar
Sounds like a wheel bearing to me. Might want to check for excessive play at all four wheels. I've never had to replace a front one, but I've had to replace 3 in the rear (one side twice).
Good luck!
Old Feb 21, 2006 | 07:46 AM
Max_Gator's Avatar
Thanks - If anything it must be the front bearing.
pears
Sep 18, 2015 05:25 AM
lrb6805
Sep 17, 2015 04:49 PM
Bonka
Sep 14, 2015 11:18 PM
thenewguyy
Sep 12, 2015 11:12 AM
ballerchris510
Sep 11, 2015 05:29 PM
