throttle cable slack
Old Feb 24, 2006 | 09:01 AM
JaKillz2's Avatar
just a quick question, noticed my throttle cables had a fair amount of slack to them (car is off) wondering if that is right or not, I havn't touched them or anything either.
Old Feb 24, 2006 | 10:27 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
there is only one throttle cable, the other is cruise control. i tightened the slack out of mine shortly after i got the car. just use a 14mm open ended wrench but i would not suggest adjusting the cruise control stuff. some people have warned that tightening too much can make it snap but i have had no issues as of 75k miles.
Old Feb 24, 2006 | 10:33 AM
JaKillz2's Avatar
what would tightening do for the drive? and when you adjust the slack, between the nuts and where it wraps over the pulley thing, wouldnt that make the pedal more loose because youd be putting more cable towards that direction? Sorry its hard to explain.
Old Feb 24, 2006 | 11:45 AM
sloppymax's Avatar
you want to loosen one side of the nut and unspin the other and pull it toward the direction of the battery. it felt as though it made the reaction for the acceleration quicker.
Old Feb 24, 2006 | 12:04 PM
SoonerFan's Avatar
Cletus
dont tighten it to much or it will raise your idle
Old Feb 24, 2006 | 12:51 PM
JaKillz2's Avatar
i get HOW you do it but i just dont get like.. when you make it tought on the throttle body end, then there will be excess cable on the opposite side of the nuts, leading to the pedal? wouldn't that mean there would still be slack?
PEDAL-------------N|N---\_/---Pulley Before
PEDAL-----\_/--------N|N------Pulley After
see what I mean?
Old Feb 24, 2006 | 01:18 PM
SoonerFan's Avatar
Cletus
the excess goes away from the bolt to the end. not towards the pedal
Old Feb 24, 2006 | 01:25 PM
Gapp's Avatar
***Don't jack with it***
Old Feb 24, 2006 | 01:32 PM
SoonerFan's Avatar
Cletus
the newbie has spoken
do you know where your throttle cable is?
Old Feb 24, 2006 | 01:41 PM
Gapp's Avatar
Yeah, my wife hasn't played with it in a while though.
Old Feb 24, 2006 | 01:49 PM
SoonerFan's Avatar
Cletus
very nicely put.
you have been placed on my "cool newbies not to mess with" list
Old Feb 24, 2006 | 01:58 PM
sloppymax's Avatar
mine is tightened down all the way and has not affected my idle. however i have adjusted one on a pathfinder and the idle was irratic, i assume because it affected the position of the butterfly in the TB.
Old Feb 24, 2006 | 02:06 PM
Gapp's Avatar
I actually did tighten it up a little to see if I could squeeze a little extra response out of it, but it raised the idle out of my comfort zone. Me likes to be within the comfort zone. (Okay, shut up) I'm sorry. (your an idiot) Dammit, I did it again...
Old Feb 24, 2006 | 08:24 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
Ouchhhh a great response .. you got
gigabyte
Jan 6, 2017 06:05 PM
knight_yyz
Oct 24, 2015 08:05 AM
sliptap
Sep 30, 2015 05:57 AM
pktaske
Sep 4, 2015 08:40 AM
