fog light bulbs
fog light bulbs
I did some searching and found that piaa plasmas are the best match to the HID headlights. I have the plasmas right now but one burnt out and I was just wondering if anyone knew of any others that might be brighter or a better match or possibly just cheaper. I am looking to order them in the next couple of days.
I just installed Hoen Xenonmatch in my fogs. Color is very close to hids but the output is not what I expected. I did just get the std 55 watt bulb. Delivered these were $38 with a 1 year warranty. Not sure if I would get again as I was hoping for more output but 55 watts is 55 watts.
Keep in mind a lot of states have laws against fog lights. So I dont know that brighter is necessarily better if it gives them an excuse to ticket you. For the most part that law isn't inforced but if you drove around with helaciously bright bulbs you might draw unecessary attention to yourself.
On the subject of fog lights how hard is a foglight change on these cars? On my trans am its a *****...
Changing the fogs on these are ridiculous. My denali it is a 5 min job to do both and adjust the aim. On the max you have to remove a screw, bolt and pop rivet and them the 2 nuts holding in the housing. I had to jack mine up as there isnt enough room. Way too much work. None of it is hard but just doesnt seem well thought out.
I just put in maxspeeds on my front last night so I will need to adjust all of my lights. Form looking at the fog light adjuster it looks like a pain. fortunately it is something that you dont do often.
Man that sucks that its a time consuming job. It was that way on my mazda and its that way on my TA. I dont get it...its a damn light bulb, it shouldn't take more than 15 mins TOPS to take out, install and adjust...but thats just me I guess...
No halogen blue bulb will ever match HIDs exactly, just come close with a noticeable difference in color. Also, with the blue bulbs, you are losing light output. With the $$$ Piaa wants for their bulbs, save up for a good HID kit for the fogs.
Only if Nissan made it this difficult to take the headlights..
I've used Silverstars many times in past rides. They are great out of the box but seem to fad. Truthfully, seeing the Hoens, which I read so many great things about online, I wish I had just picked up some silverstars. I do think the hoens match the xenon a little better though. Either way, I dont look forward to raising the aim on the fogs!
I used SilverStar bulbs in my other cars (before I bought my I30) and while I liked the color and the brightness, I found that they burned out quickly (i.e. about 7-9 months after installation). I have read posts here and in other forums from people that have experienced similar problems. I would not recommend them.
You can get PIAA bulbs on eBay for around $40.00. I would try those instead!
I tried to replace mine this weekend with Silverstars, but couldn't get the fog light out. I was able to get to the back of the housing but didn't know what was holding the light in. What has to be removed after you get the wheelwell cover removed? I saw two plastic clips on the top of the housing but had no idea what to use to remove them.
Any help is appreciated.
You have to unclip the wiring harness, then there are 2 10mm nuts holding it in place. After those are removed push the fog light out towards the front of the car.
I can't post yet, So I'll ask my question here...It is related though.
Anyone, Install HID fogs on their 02 max themselves? Are the 00-01 installation procedures the same for the 02-03? I was thinking maybe the yellow capsules from HID tech but I think I want to do HID fogs, like 4300k or 6K.
I went back to stock cause aftermarket burns out to fast and I believe they cause cracking of the lens. Nothing you get is gonna match the stock HID so I decide stock is just fine with me.
plasmas look so good but both of mine just blew out with only 11 months of use.....looking into hids but don't want them too bright. absolutely love the look of plasma but so quick to burn out....any suggestions on hids....
I just went to Wally World and bought some of the SilverStars. But once I actually looked at my blown foglight, I noticed that the fog light housing has a huge crack in it and it's filled with water. I'm going to assume the bulbs that I put in here are going to blow quite rapidly so long as this is the case.
Is there any decent, somewhat-OEM looking replacment for these? I'd prefer a non-diffused light but I don't really want to spend $200 or $300 putting HIDs in there.
Running PIAA Ion Crystals right now, but I have Eurolight Fusions for high beam. They are bright and do a good job matching the HID's as they are only somewhat "whiter" than the low beams.
FWIW, '00-01 came with 35w fog bulbs and 2k2+ have 55w bulbs from the factory.
undercarraige splashguards...
i was thinking...my undercarriage splashguard (name??) was torn from semi-truck tread left on the highway so i took it out. mainly the drivers side. i noticed on that side, the fogs burned out quicker. do you think that not having a undermotor splashguard affects the foglight?
The Frye
Sep 2, 2021 11:03 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxima30
Sep 7, 2015 06:13 PM
