Front Sway Bar
Old Feb 28, 2006 | 06:23 AM
miksen's Avatar
FU, FU, FU, You're Cool..
Front Sway Bar
I feel ashamed to ask this but I think my front sway bar or some other linkage may be loose...I have clunking going on on some bumps and not on others, it is very inconsistant yet happens very often. I would like to check for looseness and replace the FSB bushings.
I can not easily see what looks like a sway bar when i look under the from the front lip. Can anyone guide me, give me a link or post/ email me a pic of one.
Sorry to be two years old.
Old Feb 28, 2006 | 06:26 AM
Progress's Avatar
It's business time.
The swaybar doesn't hang under the body of the car, only the ends and links are visible, I believe. If you jack up the car you should be able to track it starting at one of your wheels. If you have a sound like you wheel is falling off it may be your FSB end links. I had this problem.
Old Feb 28, 2006 | 06:32 AM
Barc's Avatar
I would say it is the end links. Most folks who have had the symptoms you describe, myself included, have had to have them replaced... and at least two of us have had to have them cut off with a torch.
Old Feb 28, 2006 | 06:47 AM
miksen's Avatar
Yes, someone else mentioned to me that may be the problem.
What was the damage? Is it possible to fix yourself or would I be better off just having it done.
thanks for your help
Old Feb 28, 2006 | 06:48 AM
rbrown81's Avatar
But why is teh Rum gone?
subscribing
Old Feb 28, 2006 | 06:50 AM
papasuede's Avatar
FSB, End LINKS, NOISE.
I had both endlinks replaced and noise is still there, check this thread, you might be experiencing the same issues......
http://forums.maxima.org/showthread.php?t=295640
Old Feb 28, 2006 | 07:04 AM
Progress's Avatar
It's business time.
The dealer just said they were broken. Rust had to do with it. My warranty covered it ($200) but I paid for an extra hour of labor due to rust.
Old Feb 28, 2006 | 07:15 AM
Puppetmaster's Avatar
Here's Polo's write up on the sway bar bushings replacement:
http://digitalpolo.com/2002MaximaSE/.../FrontSwayBar/
It should have some pictures that may be of use to you.
Old Feb 28, 2006 | 07:35 AM
miksen's Avatar
Thanks Puppet
Old Feb 28, 2006 | 08:21 AM
super6's Avatar
may also be the strut mounts, they make more if a clunk noise.
Old Feb 28, 2006 | 09:11 AM
boondoxmax's Avatar
End links. PITA common problem with the max
Old Feb 28, 2006 | 09:16 AM
miksen's Avatar
Yep I'm going to start with end links....seems to be the more common problem here. Plus I have not modified my suspension in any way so I do not think it is struts/springs or anything related to the two
Old Feb 28, 2006 | 09:36 AM
97neptune's Avatar
if its the transverse links youre talkin about, id go right back and get reimbursed for that hour that you paid for. Nissan will pay for that extra hour if your dealrship calls it in. this was a safety recall, customer pays nothing!
Old Feb 28, 2006 | 09:55 AM
Progress's Avatar
It's business time.
Really? I have no idea about the transverse link. How do I confirm this?
What recall?
http://www.nissanusa.com/form/0,,act...-51054,00.html
It doesn't include 2000s.
Old Feb 28, 2006 | 12:58 PM
papasuede's Avatar
http://www.greghome.com/Greg's%20Garage/2002MaxSE/TLinkRecall.htm
I just did a google search and found this???
lowpost99
Oct 26, 2025 06:53 PM
adamgalazka
Feb 5, 2023 08:24 AM
wyobbagy
Jan 3, 2023 12:03 PM
alahjahwan09
18
Sep 21, 2015 09:12 PM
jfl330
Sep 4, 2015 01:44 PM
