Throttle Body Question
Throttle Body Question - Now with PIC
I recently bought a TB from a member here and it has a TPS with 2 connections and not one like my current one. My current one is sticking and other problems including the TPS. I wanted this one because it was a TB that did not stick and came with a working TPS. Can I use this one or am I stuck with a TPS that I can not use.
I have a 1995 5sp and the TB I got came off a 1996 5sp.
Thanks!
Frank
Thanks!
Frank
I looked in the Factory Service Manual, all models 1995-1999 have the TPS which is the bottom terminal on your original post. The other terminal, the top one is the wide open/close throttle switch. I'm still confused on why yours only has one terminal, I think that Nissan made some models with no wide open/close throttle switch. I will look in to this and get back to you.
My 95 only has one TPS connector and I would assume all 95s only have one. You can probably still use the 96+ TPS and just leave on connector unplugged.
95s are ODBII, the connector is on the passenger floorboard. However cars were not required to be until 96, so 95 Maximas are 1/2 way. 95s do not have all of the sensors, but you can hook up a ODBII unit to it.
bryants95max
Oct 2, 2015 12:52 PM
97_GXE
Sep 15, 2015 06:47 AM
