Battery died and now dc is stuck in player and cd player wont work
Ok my battery died. When I jumped it the radio worked but the cd in the player will not be ejcted or can I listen to it.
A freind of mine said I need a code because it has an antitheft system... is this true? if so how do I get the code?
no code, but you need to manually remove the disc. the same thing happened to me so i took it apart and slid the cd out. you may be able to stick some pliers in there (well something thin) and pull the cd out.
I've disconnected my battery plenty of times to work on assorted electrical stuff, and I always had a CD in it. To solve this, I hit eject, and a few days later the CD would usually randomly eject itself. Get an mp3 and AUX audio, problem solved.
wow every time I disconnect the battery and reconnected it ejects on it own. What kind of HU do you have. If you don't want to mess up the cd don't stick anything thin or pliers to pull it out.
I tried sticking tweezers in from the front but I could not even grip the cd and hope I did not harm anything.
How do I disconnect the battery and is it hard to re connect it? and when I reconnedt it should it eject or when I disconnect it should it eject?>
remove the positive terminal cord from the battery(should be red) you will probably need some kind of wrench/rachet, wait a couple of seconds and them put it back on....this resets the memory on the stereo and the eject button might work after you REconnect the battery
CorollaULEV
30
Aug 9, 2021 08:11 PM
Rage Maximus
Sep 3, 2015 12:26 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
Works for me every time a cd gets stuck
