car won't start
car won't start
Yesterday, the two times my 98 maxima started, it made a high pitched whistle or whirr kind of sound, which is not usual for my car. Once it started up, I couldn't tell anything was out of the ordinary and I dismissed the noise at startup. However, in the afternoon, I was going to go out, and got in my car to start it up. The engine won't even turn over now. I don't think it's the battery because the radio and windows still work as normal, and the battery and alternator were changed under a year ago. What do you guys think the problem might be? The starter or something? And at least one oxygen sensor has been out for a while now, but I don't know whether that has anything to do w/ it. Any advise would be appreciated.
The car has about 136K miles and is an auto, if that makes a difference to anyone.
On a side note, it's also about time to change my oil. since I can't use the search to efficiently, what are some opinions on Royal Purple.
We need more info than you've given us. Could be almost anything, like a bad battery terminal contact, starter failure, or a bad ignition switch. What happens when you try to start it? What sounds do you hear, if any? When you turn the key is there any sign of current drain, like the dimming of dash lights for instance? BTW an oxygen sensor won't affect starting.
Originally Posted by Eyemfaster
when i turned the key, almost nothing happened. turned out to be a bad starter. ($650 later it's good to go again.)
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
BobMax
Aug 15, 2015 12:35 PM
