0902 & 0608 Ses Help
Old Mar 11, 2006 | 07:49 PM
darklegend06's Avatar
HELP I was looking at the codes on my sister's 99 maxima and I got two codes
0902 = undefined
and
0608 = cylinder 1 missfire
can a bad coil pack cause a missfire? If not what can cause this missfire in this cylinder. I would understand if some timeing was off somewhere and cause all the other cylinders to missfire too but only one. so i can kind of conclude that it might be the coil pack cause the 99 are known for those coil packs.
also for the 0902 code I looked it up and it came up as O2 sensor rear. So I'm not really worry about that. It shouldn't be too hard to replace right?
Another thing is the SES flashed multiple time when my sister was driving it approx 8 times. That shows that there was an issue while she was driving right.
Thanks org members, any inputs are welcome.
Old Mar 12, 2006 | 09:51 AM
bump anyone?
Old Mar 12, 2006 | 09:56 AM
90EightSE's Avatar
Regarding code 0902. From the '98 Fac. Serv. Manual p.EC-214:
"The ECM performs ON/OFF control of the rear heated oxygen sensor heaters corresponding to the engine speed. Malfunction is detected when: The current amperage in the rear heated oxygen sensor heater circuit is out of the normal range. (An improper voltage drop signal is sent to ECM through the rear heated oxygen sensor heater.)"
For code 0902, on p.EC-217, it lists to check the following about the Rear Heated Oxygen Sensor:
<>15A fuse
<>Harness connectors
<>Harness for open or short between rear heated oxygen sensor and fuse.
Don't know about ease of replacement but looks like you need to be careful not to get burned by the exhaust which it is right next to.
Old Mar 12, 2006 | 11:42 AM
rypace's Avatar
As far as 0608, Every time I've gotten a cylinder misfire code on any of my family's 3 Maximas, It's been due to bad coil packs.
Old Mar 12, 2006 | 10:10 PM
Thanks you guys. by the way 90eightse what service book do you have? I thought it would be the coil packs, dang those things.
Old Mar 13, 2006 | 10:32 AM
90EightSE's Avatar
I have the 1998 Nissan Factory Service Manual published by Nissan.
spencerwh1
Jun 30, 2016 05:44 AM
yat70458
Aug 3, 2015 01:16 PM
maxima297
Aug 3, 2015 12:50 PM
Jose
Aug 4, 2001 06:59 AM
