Sticky antenna
Old Jun 12, 2001 | 10:49 AM
poz
I have a 1996 GLE and a 1997 GXE. The antennas do not like to go completely down. They like to get stuck in the second to largest piece of the antenna and stick out about 4 inches.
I tried the WD-40 trick on my 96. It worked until we had a light rain. Then the antenna returned to sticking up. It's real irritating.
Any suggestions? I've seen other Maximas with the same body style with the same problem.
Old Jun 12, 2001 | 11:07 AM
Eric L.'s Avatar
WD-40 doesn't last long enough. Try some dry lithium grease or some other lubricant that doesn't dry up. Oil up the antenna, and have someone else operate the radio while you "assist" the antenna up and down.
Old Jun 12, 2001 | 11:50 AM
MaxedOut97SE
I had that same problem, it WAS annoying. But if you lubricate the antenna enough, it should fix.
PH98I30
29
Feb 10, 2025 12:03 PM
chisam14
Nov 6, 2018 08:56 PM
DBear
Sep 14, 2015 08:33 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
Violator
Sep 9, 2015 10:14 AM
