Boring 2k1 throttle body...
I'm wondering if there would be any negative side effect to have my 2k1 throttle body bored ? I was told that this could increase the throttle response substentially. Does anyone has something to say about that, positive or negative ? I was thinking of buying an extra throttle body and have it bored so if something goes wrong I can still put the oem back.
Thanks for any input.
Hey Larrio, thanks for your input. It made sense for me to go the 2k1 TB, because of the direct fit, the guy who does the job is very professional and experienced, he does that for living. I'll keep you informed once I have it installed on the max.
cheers
AA
cheers
AA
cheers
AA
cheers
AA
The guys charge me 100$ US and the turnover is 5 days, he told me
( based on the pics of the 2k1 TB ) that he can bore the TB - 4mm.
I dont have is e-mail here with me but I'll let you know over the week-end.
I'm willing to be the guinea pig and then see how it work on the max and let you know asap.
Cheers
AA
Cheers
AA
Originally Posted by qballjr13
What is the stock difference between a Gen 5 and a Gen 5.5 throttle body? If you switched them stock for stock, would it be worth the $30?
tb porting
Having worked in a high end Machine shop as a 5 axis CNC programer and operator porting and polishing cylinder heads, intakes and throttle bodies.
I can tell you just a tb port wont do much if anything. The tb opening is already as big as most intakes if not bigger that there is now reduction in flow. And for a $100.00 bucks you could spend it elsewhere I'm sure.
The 5th gen is cable driven and 65mm
TallTom
57
Oct 14, 2025 05:16 PM
