Trouble installing front sway bar
Old Mar 16, 2006 | 01:30 PM
Parker Woodruff's Avatar
Trouble installing front tower bar
I got a front tower bar off ebay (custom maxima), and i've unscrewed all the nuts on top of the struts. now when I look from the front of the car at the left side, there's some sort of connection that looks like I'll need to remove. What is this connection and is it safe to remove. Let me know if i really don't need to remove this. I checked the sticky on the how to's but the link no longer works. I also looked up at the front on maxima.org and it's being performed on a 4gen.
Old Mar 16, 2006 | 01:40 PM
MaxBoost925's Avatar
Drug Money
Front Strut Tower Bar FTW!
Do you know what brand the bar is?
Old Mar 16, 2006 | 01:42 PM
steven88's Avatar
Need A Light?
He just said its a custom maxima
Old Mar 16, 2006 | 01:43 PM
Jasovanni's Avatar
Yes, you can remove, install the bar, then reinstall the part.
J
Old Mar 16, 2006 | 01:46 PM
J
thanks for the easy reply. Does it just snap out (kinda like the side marker lights do)? Also, what does this wire do inside of the engine (basically...what's it's function)?
Old Mar 16, 2006 | 01:51 PM
steven88's Avatar
Need A Light?
are you talking about the electric connector on the passenger side of the strut tower? I dunno what it does, but you can disconnect it and reconnect it back....
Old Mar 16, 2006 | 01:52 PM
Yes, thank you.
Old Mar 16, 2006 | 05:39 PM
2002 Maxima SE's Avatar
I had a hard time disconnecting the plug. I usually break these things, so I undid the two bolts holding it to the shock tower and lifted it up enough to put the FSTB rings on. Then bolted the electrical connector back on.
Old Mar 16, 2006 | 07:51 PM
Yeah, all you've gotta do is press down on the button on the bottom of the connection (it's hard to see unless you get down on eye-level with it.) Oce you see it, it comes off easily.
kingw323
20
Oct 21, 2015 08:36 AM
homeyclaus
Sep 3, 2015 06:15 PM
ef9
Aug 27, 2015 07:21 AM
Maxboy23
Aug 20, 2015 09:33 AM
MaxStock
Aug 14, 2015 10:03 PM
