Trouble installing front sway bar
Trouble installing front tower bar
I got a front tower bar off ebay (custom maxima), and i've unscrewed all the nuts on top of the struts. now when I look from the front of the car at the left side, there's some sort of connection that looks like I'll need to remove. What is this connection and is it safe to remove. Let me know if i really don't need to remove this. I checked the sticky on the how to's but the link no longer works. I also looked up at the front on maxima.org and it's being performed on a 4gen.
Originally Posted by Jasovanni
Yes, you can remove, install the bar, then reinstall the part.
J
J
I had a hard time disconnecting the plug. I usually break these things, so I undid the two bolts holding it to the shock tower and lifted it up enough to put the FSTB rings on. Then bolted the electrical connector back on.
kingw323
20
10-21-2015 08:36 AM
