Got my Zt-2 wideband and timming belt pops!
Old Mar 19, 2006 | 04:46 PM
95turbo gxe's Avatar
Well yeah It dont seem that I can get it all together now. Finally got over hard times and got my wide band in and installed it saturday morning. Well I just put this engine togther about 3 months ago (Blew a tranny and was donw for a month from then) Had Scott (boosted maxima) port the heads and we added some nice iskey cams to it. And I put it back together and have had it running for about 3 month and finally got the wide band in on saturday. Well decided not to get on it to hard intill I got back from this trip this week end I took up state.Well on the way all of a sudden the car just cuts right off. No power lose or anything. So I pull over and are like WTF! ok It would not recrank. So I knew a a sensor had to shut it down. SO I check the ecu for codes and got the cam positon sensor and the knock sensor . So I check for fuel pressure and it was fine then I found I had no spark. WEll I took off the distributor cap and seen the rotor button wasnt spinning.So I call mtcookson to see if He had any Ideas about it And said If I was luck the distributor had broke. So on the side of I-26 I took it out and seen that it was fine and when I spent it over the cams would not turn. Im just hoping the new upgraded valve spring I put it would have may return the valve and none are bent. Dam and the wide band was so sweet too.
Old Mar 19, 2006 | 04:58 PM
maxmaxima91's Avatar
that sucks man
Old Mar 20, 2006 | 02:27 PM
subs1000w's Avatar
didnt you replace the belt when you put the cams in
Old Mar 20, 2006 | 03:24 PM
Yes when I had the motor tore down and put the cams and ported heads on I replaced the timing belt and tenioner both.
Old Mar 21, 2006 | 03:28 PM
Boosted Maxima's Avatar
How did you set tension on the belt?
Too tight and it has a slight whine to it....
Too loose and it skips or breaks.
Proably what happend..
Hope those valves didn't bend
Good luck,
Scott~
Mahmuth
Aug 16, 2024 08:23 PM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
markevans999
Oct 25, 2015 08:27 AM
homewrecker
Sep 24, 2015 07:01 PM
