Sponsored by:
Sponsored by: CARiD
350Z injectors with 350Z ECU?
Old Mar 26, 2006 | 09:35 AM
!PrjctMax!'s Avatar
This might be a re-post or just a stupid question......but if you were to pair the 335cc injectors from the 350Z and the ECU from it as well, then would this result in power gains, or just pointless fuel waste? Thanks and sorry if this is in the wrong sections or if it's a re-post.
Old Mar 26, 2006 | 09:48 AM
Jason R's Avatar
aka UNCDooD
chances are the 350z ecu won't work.
Old Mar 26, 2006 | 10:33 AM
eng92's Avatar
Additional fuel capacity isn't going to help you unless you can get more air into your engine to burn it with.
You share the same ecu connector with the 350Z but I do not know if the pinouts are identical. You will lose your VIAS control if you switch ecus.
The Z ecu may provide a little more aggressive tune (ig timing and afr) but you would be able to attain that and more with a number of aftermarket engine management systems.
Old Mar 26, 2006 | 11:32 AM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
right now we have members running a g35 ecu, and a z ecu in the 6th gens.
they both need some debugging, but they work fine...
as for injectors and more fuel, just get a technosquare ecu and have them program the injectors to dump more fuel...
wait till I get mines all set before you do anything...
Old Mar 26, 2006 | 03:13 PM
Nealoc187's Avatar
SLOW
Yeah that's exactly what you want...
Old Mar 26, 2006 | 03:44 PM
SR20DEN's Avatar
VQ Wizard
The best option for most is to just get Z33 L-Spec software, with a 315cc injector map, from TS.
Old Mar 27, 2006 | 01:55 AM
!PrjctMax!'s Avatar
Nice thanks for the replys, and yes I am aware of the the technosquare ecu, but i'm just looking around for other possible ideas and I WILL wait/probaly get the technosquare ecu after you done with it!
Old Mar 27, 2006 | 09:25 AM
NmexMAX's Avatar
dot dot dot ...
Since you have an A34, your option of using the Z33 ECU is more applicable compared to A33B's.
TS may still charge you full price for the Z tune though.
I wouldn't alter anything fuel related (i.e injectors etc) unless your a/f shows a need for more fuel, and you're at your limit with your current A34 set-up.
Old Mar 27, 2006 | 09:54 AM
MardiGrasMax's Avatar
Will a 350Z UTEC work?
Old Mar 27, 2006 | 10:08 AM
SR20DEN's Avatar
VQ Wizard
For a A34? Yes. Iv'e plastered that all over the A34 forums. I still say it probably needs the patch harness though.
Old Mar 29, 2006 | 06:55 AM
rbrown81's Avatar
But why is teh Rum gone?
Its pricey. Is it worth 500 dollars SR20?
Old Mar 29, 2006 | 06:57 AM
NmexMAX's Avatar
dot dot dot ...
Old Mar 29, 2006 | 09:34 AM
vsamoylov
and who fall into the catagorie of most?
Old Mar 29, 2006 | 11:27 AM
rbrown81's Avatar
Originally Posted by NmexMAX
Call me crazy but I find myself a little amused with the idea of paying 500 dollars for a program that probably took the programmers about a week to plan/design and impliment and 20 minutes to modify the programming to run on the different spec engines.
Unfortunately they can get away with it because we dont have any other viable alternatives.
Oh, and does it really get rid of that dip in the midrange where the VI kicks in?
Old Mar 29, 2006 | 07:03 PM
SR20DEN's Avatar
VQ Wizard
Most people know how to screw in a lightbulb. You must feel left out.
Old Mar 29, 2006 | 07:46 PM
NmexMAX's Avatar
dot dot dot ...
Whoever said it would?
Old Mar 29, 2006 | 07:51 PM
Kevlo911's Avatar
Kevlo for President
Old Mar 29, 2006 | 08:47 PM
rbrown81's Avatar
errr... puppet gave me that impression
Sorry joel!
Old Mar 29, 2006 | 08:55 PM
NmexMAX's Avatar
dot dot dot ...
You misunderstood him that's all. You drew a false conclusion because you don't know how it works.
Old Mar 29, 2006 | 08:57 PM
Puppetmaster's Avatar
Sorry joel!
I don't seem to recall saying anything like that.
Old Mar 29, 2006 | 10:12 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Old Mar 30, 2006 | 04:18 AM
rbrown81's Avatar
Hmm. Okay
So splain it to me lucy
Old Mar 30, 2006 | 05:33 AM
vsamoylov
haha but most people are idiots.
Old Mar 30, 2006 | 05:43 AM
NmexMAX's Avatar
dot dot dot ...
I would if my name was lucy.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
gigabyte
Jan 6, 2017 06:05 PM
knight_yyz
Nov 1, 2015 01:34 PM
