I just changed my fuel filter...
I just replaced my fuel filter...
Took about 10 minutes...I removed it from the bracket and used an offset phillips head screwdriver to loosen the screw, then hand-turned it the rest of the way. I used the plastic plugs that were on the ends of the new one (which I noticed was 2x longer than the old one) to cover the holes on the old one as I removed the hoses (to minimize the fuel spilling out of the old filter when I removed it). I must have done it correctly because it did start and I drove around the block after I finished, and no leaks when I returned. Woo-Hoo!! What I noticed was that there is no more hesitation when I hit the gas from a stop; immediate throttle response form the pedal! I guess after 91,000 miles, the old one was pretty clogged up.
The only down side are the hives that have broken out on my arm where some gasoline spilled on my skin from the hose as I pulled it off. I showered immediately afterwards and put some hydrocortizone on it, so hopefully it will be gone by the morning.
Originally posted by Supa Lao
congrat man...and it only took you 10 mins. I remember when I changed mine, it had to have taken like an hour, 40 of those mins was just taking the tubes off the filter
Originally posted by Mr. Nismo
Damn ten minutes! 25 minutes is on the average. Usually the hoses get stuck and on the fourth generations you have less space to work with.
Re: Any particular brand?
Originally posted by hadman
What's recommended? How much did you pay for the filter?
Please visit the "4th Generation Maintenance Items" sticky post in the 4th Gen forum. All details are in there.....
I got it from an import parts store that is one of my accounts from work. He's ships/recieves his parts w/ my company; I hooked him up with better shipping costs, and he sold me the filter for $5...I think it retailed for around $15, but looking at some of the other posts, I think you can find them around $10 or so.
Re: Re: Any particular brand?
Originally posted by bill99gxe
hadman,
hadman,
I used the Monroe Expert Series @ $19.25 per shock, which I picked up at Carparts.com . Part #901223
Thanks for your help.
Hadley
Re: Re: Re: Any particular brand?
Thanks Bill - Of course I should have looked there. What was I thinking? Just to note, I recently changed my Hood Shocks (lift supports) Didn't check the General Maintenence Items first, but I came out okay. I give an in depth description of what, where, how, on the 3rd Gen forum under "HOOD SHOCKS", if you want to add any info.
Hadley
Hadley
I've already "cut and pasted" your findings on my computer, with which I'm constructing a similar "3rd Gen Maintenance Items" sticky that will be inserted in the 3rd gen forum sometime next week.
Thanks for your help, and I'll be sure to credit you with that.....
Re: Re: Re: Re: Any particular brand?
hadman,
hadman,
Would like to add at this time, that Altezzas DO INDEED suck, and I am less than thrilled with the BMW headlight conversion. It just doesn't look right, fit right, feel right.
Right?
Regards,
Had
10 minutes?? AND your car had ABS?? Jeez, you're good, real good. I tried it on mine, and got very frustrated with those ABS lines in the way. I gave up and ran to my mechanic
I guess I should have had the offset screwdriver. Is that like a screwdrive at a right angle??
DW
DW
Originally posted by The_quorum
I've been looking/planning on doing this for several months now, so I sort of had a plan of attack going in. The offset screwdriver was the biggest help. I tried a regular length one at first but it kept hitting the ABS lines.
The offset screwdriver...
Yes, it's about 2-3 inches long, and it fits right in the palm of your hand, so if you can get your hand in there you can reach it...and like I said, I just loosened the screw, then used my fingers the rest of the way. The hoses slipped off w/ no problem.
Re: The offset screwdriver...
Sweet! 10 minutes? I think I spent 30 minutes total, but maybe 15 of that cussing!
In any case, I would probably be better off with that offset screwdriver you mentioned or at least a short stubby one.
Also, I got a Fram fuel filter. After reading the recent Maintenance Sticky, I'm now regretting that as it seems that Fram doesn't really make quality filter goods. No matter, I guess I will be replacing it after 15k miles. My bad anyways. I guess I should have been tipped off by the *plastic* upper cap/lid.
Re: Re: The offset screwdriver...
I think you may be confusing FRAM oil filters and fuel filters. It's the oil filters that hace the bad rap. I don't think anything bad has been said about the fuel filters. Besides, the job of a fule filter is much easier than that of an oil filter.
DW
DW
Re: Re: Re: The offset screwdriver...
DW
DW
homewrecker
Sep 23, 2015 03:41 AM
