Please help service engine what did I do?
I remember someone posting something about their RPM not passing 2k well mines isn't, and someone said the MAF code was by the air filter welli clicked on the gray thing in this picture and took it a loose and now it say service engine what is wrong?
The part that im talking about is that lil gray thing with the black hose coming from it with the white and red wires.
ohhhhhh yeah. the maf code is by the air filter, and if you click on the gray thing you can take it a loose. then it say the service engine. the part your talking about is the lil gray thing with the black hose coming from it with wires colored white and red.
to reset your ecu, all you gotta do is turn the thing down there.
and read the stickies for christ sake.
i'm guessing english is not your native language?
check if the hose that you "clicked" has not come loose. reset the ecu by using philips screw driver and turn the mode selector on your ecu. more details on the stickies on how to reset the ecu.
For one thing, I don't have to type correct english or speak correct english I speak however I wanna speak, you can't do anything about it so you might as well get OVER IT!
I couldn't understand what you wrote either.
Originally Posted by the_3d_man
wow... sounds like you don't really wan't any help.
well maybe i should rewrite it.
Well im having problems with my RPM it lies at 2 thousand it will not pass it. So I went to this website to post a topic about it but someone already posted a topic about it and stated that it could be the MAF, and stated were it could be located and I tried it and my check engine light came on when I started the car, and it will not go away. The part that I had taken a loose is aside the air filter, I thought that it may have something to do with my RPMS but I don't have a clue. Anybody knows what I did wrong.
Originally Posted by clive
That is caused by the MAF being disconnected, the MASS AIR FLOW sensor. It is nothing to do with the rubber hose, that's only a breather tube. The device is the small square plastic box with a connector that has wires coming out. And it is BLOODY EXPENSIVE so if you have trashed it, hard luck.
So how would I know if I messed it up?
Originally Posted by HallKemar
hes from LA., you guys should leave him alone.For the simple fact that their education level is below average
Did anybody ask you to type a stupid response like that because you don't even know me like that you stupid *** *****.
Back to the discussion..I had the same problem which your facing, the tactic I used to fix that problem was simple..I simply unscrewed the Engine Oil Cap and added a half of quartz of purified water into my engine..After I did that, I allowed my car to run for about 5 minutes, no rev no nothing..After that was done, i turned off my car, then turned it back on then the CEL light came off..You may be thinking, water in the engine? Isnt that dangerous!? Obviously it isn't since it fixed my problem..With that being said 97_Max..Follow those simple instructions so your Service Light can turn off..
That little gray thing with red/white wires coming from it is your mass air flow sensor... IF u disconnected it it will turn on your cel, and your car will run like shi*.. Oh and someone please explain to me by adding water to your engine it will cut off the cel light??
That's the worst advice i've ever heard..
If you intend doing your own maintenance you'd better start learning your way around a modern car's sensor systems, the MAF device is common to pretty much all modern petrol-engined vehicles (and diesels too, for all I know)
I thought this was a forum where you could get good advice and have your questions answered. Lately I've seen a lot of kids bagging on guys because they don't know as much as the guy with 500+ posts. This isn't "Yo Momma" or am I wrong?
I try to help out anyone, but when someone post multiple times giving dumb info about putting water in your engine it makes me mad.... Some kid would probaly be tempted to try it, b/c he read it here... I got ragged on a lot when i first posted, and was told "to get used to it" basically...
That was my concern, some kid with locash taking what he got here as the law and then messing up his car. I notice a vast majority of the guys here are 18 to 25 and do their own work. That used to be my philosophy until I had no choice but to find a mechanic when I owned a Saab and a Volvo.
shilov
Feb 19, 2024 09:40 PM
