wheel hub nut size.
Old May 9, 2006 | 04:37 PM
maximaintheface's Avatar
wheel hub nut size.
is it a 30mm nut? i tired a 28 and it was to small seems like it would be a 30mm. thanks
Old May 9, 2006 | 04:41 PM
ti2tmax's Avatar
Has his VINs memorized
the one that holds the axle on the wheel hub? It's a 36mm. It's the one that you have to take out the cotter pin to get to...
Old May 9, 2006 | 04:42 PM
whoa 36mm damn... i just tried a 29mm and it seemed like it was almost a fit. that is one big **** socket.. thanks man.
Old May 9, 2006 | 04:49 PM
ti2tmax's Avatar
No problem. I'm almost positive they didn't change from 96-99 and mine is 36mm. Just get one from NAPA and if it isn't right, take it back. They let you with receipt
Old May 9, 2006 | 04:50 PM
pmohr's Avatar
No more Maximas...
Yea, the axle nut is a 36mm. You can get axle nut sockets at most if not all auto parts stores, but you have to ask specifically for that because most places don't have regular 1/2" sockets that large.
That nut requires a good ~250 ft/lbs, so it's going to be a ***** breaking it loose. An impact works pretty well (even an electric impact, it's what I used during my trans swap). If you don't have a torque wrench just get a long *** ratchet and a pipe or just use a breaker bar and pretty much stand on it, you can't really shear off that large of a thread without some pretty tremendous pressure. I would recommend a cheap Craftsman torque wrench though, in 1/2" drive, it comes in handy and it's good to keep things torqued down to specs.
Old May 9, 2006 | 04:55 PM
i have a 50 gallon compressor it will be no problem and if all fails i have a 6ft breaker bar
Old May 9, 2006 | 04:56 PM
ti2tmax's Avatar
Yeah, chances are one side or the other will be a total SOB to get off. Mine was the drivers side! I had to use an 18" breaker bar with a 3' pipe on it to lift it off. me bouncing on it wasn't doing it. Make sure your car is well supported. Also, it would probably be easier to loosen it up while the car is still on the ground.(if your socket you get will fit in the hole in your rim...)
Old May 9, 2006 | 06:41 PM
1991tsi's Avatar
autozone (if you have them) rents the sockets. they're special and extra deep. i secured a crowbar between the lug studs to keep the hub from rotating. it will take alot of force...
Old May 9, 2006 | 07:57 PM
ugh mine isnt 36mm it was way to big? 29 almost fit so i guess its 30mm? thats wierd that its not 36mm like you guys said..
Old May 9, 2006 | 07:58 PM
ImmaSquashYou's Avatar
if you're planning to change the axle, might wanna look at raxles if you haven't already. I just went through 2 differen axles today from napa. Winded up giving that crap back to them and ordered from raxles...wasting my time
Old May 9, 2006 | 10:09 PM
im doing my rear hubs not front fyi i should have said that in the begging. are the front and rear bolts differnt sizes?
Old May 10, 2006 | 02:54 PM
it was a 30mm socket that i had to use. thanks though.
Old May 10, 2006 | 04:12 PM
ti2tmax's Avatar
Yeah, 36 is the fronts. Thats what we thought you meant...
Old May 10, 2006 | 05:29 PM
sorry i forgot to say rear at first.
Old May 10, 2006 | 06:24 PM
ti2tmax's Avatar
no problem glad you got it figured out!
lowpost99
Oct 26, 2025 06:53 PM
londonflu
40
Sep 25, 2015 09:11 AM
camako
Sep 22, 2015 04:27 PM
bumpypickle
Sep 19, 2015 01:07 AM
maximusrising
Sep 2, 2015 09:55 AM
