wheel hub nut size.
Originally Posted by maximaintheface
whoa 36mm damn... i just tried a 29mm and it seemed like it was almost a fit. that is one big **** socket.. thanks man.
That nut requires a good ~250 ft/lbs, so it's going to be a ***** breaking it loose. An impact works pretty well (even an electric impact, it's what I used during my trans swap). If you don't have a torque wrench just get a long *** ratchet and a pipe or just use a breaker bar and pretty much stand on it, you can't really shear off that large of a thread without some pretty tremendous pressure. I would recommend a cheap Craftsman torque wrench though, in 1/2" drive, it comes in handy and it's good to keep things torqued down to specs.
Yeah, chances are one side or the other will be a total SOB to get off. Mine was the drivers side! I had to use an 18" breaker bar with a 3' pipe on it to lift it off. me bouncing on it wasn't doing it. Make sure your car is well supported. Also, it would probably be easier to loosen it up while the car is still on the ground.(if your socket you get will fit in the hole in your rim...)
if you're planning to change the axle, might wanna look at raxles if you haven't already. I just went through 2 differen axles today from napa. Winded up giving that crap back to them and ordered from raxles...wasting my time
lowpost99
05-16-2021 11:18 AM
londonflu
40
09-25-2015 09:11 AM
