blinking red battery light
Hi fellows i have a problem with the dash board battery light,it started when i turn on the ac,it wld start blinking, but it wld stop after a while now it is doing it when i accelerate the car {when i give it gas},can someone tell me if they had this problem before, i have brand new battery and alt., second problem is when im going uphill with my ac on the engine looses power, please help driving me crazy. Thanks ahead. JA
Before anyone messes with the wiring, go to your nearest hardware store and buy
a spray can of electrical contact cleaner should dissolve
disconnect battery
clean + and - terminals on battery and car
disconnect connectors at your alt and give them a good spray and clean
connect batt
take car to Autozone have them test batt and alt, and pull codes
check both belts for cracks and tension replace if necessary
good luck
disconnect battery
connect batt
good luck
Originally Posted by colinod
Why won't my battery light turn off. It's fine as has never failed.
If your have access to a multimeter,check the voltage when it is running..It should be around 14 to 14.5 volts at idle...
I drove my old (1st gen) max with a bad alternator for a while. The alternator charged fine, but the Voltage Regulator was failing. it finally did fail, during a snow storm when I was on the south side. talk about bad timing. Driving home on a battery with no lights, heat, or wipers with RWD in a storm
The Frye
Sep 2, 2021 11:03 AM
Maxima30
Sep 7, 2015 06:13 PM
