Tranny Mount
Old May 21, 2006 | 06:31 PM
toddyfresh's Avatar
Tranny Mount
does anyone have a write up on changing the tranny mount on a 93 gxe and the syptoms of one going bad? any help is appreciated!!
Old May 25, 2006 | 04:09 AM
Greeny's Avatar
¯\(°_o)/¯
Write up??
1.Put jack under transmission,raise it enough to let the pressure of the mount
2.Unbolt bad motor mount.
3.Put new m/m in place of bad one ,bolt it in...
Look at the center of the mount where the rubber part is for cracked/broken areas....
Old May 26, 2006 | 04:37 PM
Hectic's Avatar
sticky??
Old Apr 3, 2007 | 02:13 PM
2Legal4Me's Avatar
has anyone poly there tranny mounts and engine mounts if so i need to know the pros and the cons of it.
Also i need the ratio to do so and the steps for prepping and drying procedures
Old Apr 4, 2007 | 06:25 AM
nForce's Avatar
The Computer Guy
I have a my old tranny mouts from my AUTO I converted to 5 Speed so if you need mounts let me know.
Old Apr 4, 2007 | 07:20 AM
Tom's Avatar
Tom
I had mine changed about 2 months ago.
I first noticed that when I put my car into reverse, I would get a much larger shock at times. Then, I noticed if I stepped on the gas even a little hard in Reverse (like backing up a hill), I would feel this funny vibration past 1200 or so RPM.
I opened the hood, got back into the driver's seat. I shifted the transmission into reverse/drive and revved it lightly with my left foot on the brake. I peeked into the engine compartment through the slot under the bottom of the hood. I noticed my engine rocked back and forth A LOT. Especially when I shifted into Drive.
Sure enough, the transmission mount had sheared off (those carriage bolts looking part of the mount) when I looked at it closely.
I bought replacement mounts from NAPA (engine mounts also) and just took it into my mechanic and had it changed.
Now the car shifts smoother and all is well once again.
Old Apr 4, 2007 | 11:20 AM
'90_Maxima's Avatar
If you buy OEM transmission mounts watch out for the rear one. The replacement part I bought is different for the one I took out of the transmission bracket, although the part # is the same. It has what looks like a bumpstop on the top (that the previous one did not) but bolts up to the lower L-shaped bracket that connects to the transmission perfectly. It does not, however, bolt into the upper bracket that fits the bushing itself. The metal has to be grinded on each side of where the main bolt that fits thru the rubber bushing is inserted. It's not that big of a deal to me, but a heads up for those who don't expect it.
Unclejunebug
Apr 2, 2016 05:42 AM
fx4five
Oct 18, 2015 06:57 PM
Pnjboyzz
Oct 7, 2015 10:47 PM
fx4five
Oct 1, 2015 04:58 AM
