Help! Car Won't Start
Old Jun 8, 2006 | 06:44 PM
goobergo's Avatar
Cookin' with Gas!
Just went out to start the maxima 10 mins. after driving it and it would not start up I turn the key and I get power but I turn to 'start' and absolutely nothing happens. I don't know what to do. Here are my trouble codes:
0403(Throttle Position Sensor), 0304(Knock Sensor), 0305(EGRTS), 0401(IATS)
Old Jun 8, 2006 | 08:34 PM
99grnmaxgxe's Avatar
Dead battery?
Old Jun 9, 2006 | 08:46 AM
SBman182's Avatar
alternator?
Old Jun 9, 2006 | 09:22 AM
f550maranello2's Avatar
its the ignition switch.. if u turn the key and absolutely nothing happens... jiggle it when you are trying to start it...
then check ur batter
Old Jun 9, 2006 | 10:54 AM
buntypatel's Avatar
I would think its alternator
Old Jun 9, 2006 | 03:30 PM
clive's Avatar
100% chingon
Like f550 said, it is either the ignition switch (part inside the column cover) or possibly the throw-out solenoid on the starter motor.
Old Jun 9, 2006 | 03:58 PM
MDeezy's Avatar
It could be various different things. If you are getting nothing when you start up it could be:
-Dead battery
-Ignition switch
-starter
v
-Check the battery, try a jump
- try tapping the starter while cranking
- check the ignition switch.
A situation like this has happened to a friend, I tapped the starter while he was cranking fired up. The Gear is the starter could be stuck and thus not moving at all.
Old Jun 9, 2006 | 04:50 PM
LTU_max's Avatar
If auto try putting it in Neutral and starting.
Old Jun 9, 2006 | 04:54 PM
sickmen's Avatar
Try to tap the starter with a hammer (don’t hit it with full force just tap!) and if it starts then you need to disassemble and repack the starter. It only cost a few bucks for gear grease. Maxima has bad gear grease in the starter motor. Don’t waste your money on any parts before trying out this method.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Btheman80
May 1, 2018 04:03 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
BobMax
Aug 15, 2015 12:35 PM
