DIY STock Intake
DIY STock Intake
Has anyone here done the DIY stock intake, where you drill some holes to let in more air and maybe add a tube? If so CAN I SEE SOME PICS? I know it would be best to just get an intake but I want to see how it looks and if it actually works, cuz I heard it doesn't make noise like it would if I installed a full after market Intake or CAI.
You mean hacking the stock air box? You would bassicaly cut out holes in the bottom part of the air box. Or you can cut a hole on the top part but then youll need to put a filter there.
It should make the car louder (sound a little meaner?), will it help? Im not sure.
yeah, I think thats what it's called, I just want to see excatly how it looks like and see if it works for whoever has done it...They type of sound it makes would be good too..
Yeah, you're talking about a hacked airbox. I 'hacked' my airbox by drilling a series of holes into the bottom half of the airbox. I don't know if it makes any performance gains, but it does sound a lot nicer during WOT and accelerating.
I also removed the intake resonator so that probably helps too.
Do you know how big of holes did you make? and how many?
I have a better solution. No drilling, and it takes about 3 zip-ties.
1.) seperate upper and lower halves.
2.) remove lower airbox (and snorkel and all that other stuff if you want.)
3.) rotate the top 180 degrees (flip over), you will have to unbolt and rebolt
to the maf to do this.
4.) use a few zipties to secure the filter to the box, done.
A few things:
I have a midpipe, with a K&N and mid-pipe this sounded VERY mean (think RWD VQ35)
With a paper filter and stock resonator, it won't be as loud or have the same tone. It may sound a little muffled and motor-boat like.
I would say power gain is probably next to nothing. I think you lose some in the low and and gain some on the top end.
I went back to a ported box (removed 1 wall and part of rear wall of lower box) and I felt some increase in midrange. I did this because running the flipped box will get the filter dirtier quicker than inside the box.
I think it is a great mod because it does not take very long and has very audible results, I have done this to a few other members cars and none of them have switched back. It also is free and easy to switch to and from because you are not cutting ANYTHING.
I will post a picture of the setup so you get and idea.
A few things:
A few things:
A few things:
Thanks!
Oh ok, but wouldn't doing the flipping make the "Check Engine" light turn on and stay on even if you reset it? Pics would be perfect especially of the second one where you took off the side wall. I can't wait,
Thanks!
Thanks!
Back when I was on D2 Racing Sport coilovers
Looks good, the only reason I ask about the CEL is because I figure that it's getting a different amout of air and it might switch it on, but oh well. Have you ever thought of custom cutting a peice of, like screen door neting to cover the box so it won't get as dirty? looks good either way, Im sure Ill end up doing this mod for sure....
i just went to autozone and got an adapter and K&N filter, went home and took off the airbox, put the adapter on along with the K&N cone filter and left it at that.....it sounds awesome at WOT and i noticed a bit of a gain in power.
Looking at that picture has me thinking of swapping back to that, it's such a straight path for the intake air to take and the surface area of the filter is pretty good. With my setup now the air literally has to take a U shaped path in to the airbox, through the filter, and then through the MAF.
My only problem with this setup is how it will draw mostly rising hot air (from the engine/trans) that is trapped under the hood upon initial acceleration from a standstill. The factory airbox fights some of that, and by pulling air from the underside the air should not be AS hot.
These are moot points once the car is at speed however.
I think I will probably switch back to this setup, let me know if you want me to take pictures of how I ported my airbox and I can put them up before you start making random holes in yours
To filter the filter? The idea is high-flow, you just clean the K&N more often...
Here's something close to what you are talking about. This was my old intake setup.
I cut a 2" hole onto the filter box, and ran a 2" heater hose thru it. Then I routed the other end of the heater hose thru a 3" cut-out that I had made onto the metal panel next to the battery and down behind the front bumper. I cut the 3" hole because eventually I was going to go with the CAI intake route, which I now have.
Originally Posted by Radiohead
You should run a custom hood scoop with that setup
Stagnet04, I will snap some pics.I think I am going to grind off that stupid tab on the box to clean things up looks-wise. Now, the area that I removed from the box (if you are looking at the engine bay straight on) is the left side wall, and part of the rear wall. I left the front so to keep debris and such off the filter as much as possible.
Just keep that in mind but you can cut anywhere, do you have a spare box? If you don't, and plan on doing SOME kind of modified stock intake setup I would suggest getting the K&N and trying the flipped box first.
How it was oriented on the car.
Yeah, it was pretty ported....
I switched back to the flipped box tonight and I think I like the tone of this setup the best, the performance difference is very small between the two. I wouldn't say anything is gained or lost, but the RPM's that the engine is making better power shift from midrange to a higher RPM.
Originally Posted by Black Maxima
We are not racecar drivers. You think changing the stock intake will make your car faster? Well maybe like .007 seconds in the 1/4 mile. Oh boy that will make a big difference when you want to get to the grocery store before the huge crowd.
Hey man, when I want cheez-its....I WANT CHEEZE IT'S!....
Originally Posted by acidspit86
i did it for the sound, it sounds freaking amazing
