low gasoline light
Old Jun 16, 2006 | 07:04 PM
supazn
low gasoline light
how many miles should I go before it is too risky to drive with the light on?
I'm guessing about 40-50 miles? thanks for any info...
Old Jun 16, 2006 | 07:13 PM
Dexter's Avatar
the light is the car's way of telling you that it's your own fault if it dies out on you, but 50 miles seems like alot on the low gas light, i've never actually seen mine turn on cuz I fill up when it's half-way below the last quarter.
Old Jun 16, 2006 | 07:29 PM
semaj3708's Avatar
FEELS GOOD TO BE GANGSTA
when my light comes on for the 2nd time it means I have about 25-30 miles left. Assuming I'm not wide open on the highway.
Old Jun 16, 2006 | 07:32 PM
dgeesaman's Avatar
Maintenance Monster
When the light comes on I need about 15 gallons to refill. The tank has an 18gallon capacity. Since you're sloshing the tank when you turn, brake, or accelerate, it's really unlikely to get to the last gallon.
I've never been lame enough to find out where it starts stalling. If you're getting 25mpg, you won't get more than 75mi. Probably less than 50.
Dave
Old Jun 16, 2006 | 09:51 PM
whitegold's Avatar
I got 30 miles with the light on before it died.
Old Jun 17, 2006 | 04:57 AM
Rit's Avatar
Rit
Zero
When you're down that low, you run the risk of burning out your fuel pump. The gasoline acts as a coolant for the fuel pump. I just helped someone that burned out her fuel pump on a 2003 Pathfinder. It cost over $400 to get it replaced. You are penny wise and pound foolish when you try to get the last drop of gas out of your tank.
Old Jun 17, 2006 | 07:08 AM
HomerMAC's Avatar
Donating i30 Owner
never found out... and never wanna find out.. but AAA is in hand
Old Jun 17, 2006 | 09:19 AM
Maxgig's Avatar
I was stationed in Germany and had to drive with my light on for about 25 to 30 miles because the gas station was a ways away. I was doing well over 80mph the whole time mind you. Made it no problem but was sweating bullets the whole time. Don't try to find out keep it filled.
Old Jun 17, 2006 | 09:30 AM
NerdManXdx's Avatar
I'm in the same range as everyone else. I'll regularly drive 30 miles after the light comes on, 40 miles sometimes if there isn't a cheaper gas station around. I haven't had any problems.
Old Jun 19, 2006 | 12:12 AM
flynlr's Avatar
did 42 miles on the highway once after the light came on steady . was sweating like hell when I pulled in to get gas .. it took 17.9 gallons.
The Frye
Sep 2, 2021 11:03 AM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
TheMafia
Sep 4, 2015 08:26 AM
