Well it's parked now.
Old Jun 19, 2006 | 11:53 AM
goon9's Avatar
My little axel problem/ bearing. has went some a slight woosh woosh sound to a real grind. I think finally chewed up the bearing. So now it's parked until I can come up with money for internetautomart.
Anyway, is it possible to remove the passenger axel without messing up my preceous alignment?
Old Jun 19, 2006 | 12:07 PM
shavedmax's Avatar
SI, so long as you dont have camber adjustment bolts in the front. pop the outer tie rod from the knuckle, take the knuckle off the car and have a new bearing pressed in
Old Jun 19, 2006 | 12:26 PM
goon9's Avatar
I do have camber bolts..... Blahhh. It took me 3 aligments to get it right. Oh well, here's goes number 4. Is it really neccesary to have the bearing pressed in?
Old Jun 19, 2006 | 12:28 PM
goon9's Avatar
333333333333333333333333333!
Old Jun 19, 2006 | 12:50 PM
Greeny's Avatar
¯\(°_o)/¯
Yes, it is neccesary to press the old bearing out and press a new one in...
Old Jun 19, 2006 | 01:07 PM
shavedmax's Avatar
nah, just pull it out with a steering wheel puller and then tap it back in with a sledge hammer....................................
you may want to mark the bolts location then so that when you take them off you can put them back in the same place. if you dont change the strut or actual knuckle then the alignment is a-ok.
you can send me the 65 bucks for an alignment via paypal.
Old Jun 19, 2006 | 01:08 PM
goon9's Avatar
I only ask becuase I've changed them on ther cars without a press. By hammering the old one out. Then tapped the outer bearing on the old on top of the new to get it in. What does it cost to get it pressed?
Old Jun 19, 2006 | 01:15 PM
Greeny's Avatar
¯\(°_o)/¯
The price varies from place to place..I have a guy local that will do it for $20..
Old Jun 19, 2006 | 05:15 PM
internetautomar's Avatar
mod or sell?
you got an impact?
you may be able to get creative if you do
Old Jun 19, 2006 | 05:21 PM
goon9's Avatar
you got an impact?
No sadly.... Took it all apart tonight. It's alot wider than I expected. I'll have to get it pressed after all.
jmlee44
Oct 2, 2022 02:13 PM
gigabyte
Jan 6, 2017 06:05 PM
BobTX10
Oct 7, 2015 08:43 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
