Rebulding 2 piece rotors with pics inside
Well my replacement rotors finally came in from Baer racing. These rotors are a 2 piece design meaning the hat is made out of alluminum which equals to saving some weight of the rotor. The rotor size is 13 inches and they are from a 2004 Ford Mustang Cobra. The first set of rotors that I had I warped (dont ask how)
so I called Baer and the rotors are covered by lifetime warranty so they sent me a new set. I have to still reuse my hats from the first set. Well here are some pics of the work that is involved.
the new rotor without the alluminum hat
new rotors
new rotors
so I called Baer and the rotors are covered by lifetime warranty so they sent me a new set. I have to still reuse my hats from the first set. Well here are some pics of the work that is involved.the new rotor without the alluminum hat
new rotors
new rotors
Continued
here is a pic of the rotor and how thick it is
picture of the inside of the alluminum hat
picture of the outside of the alluminum hat
picture of one side complete. the rotor on the left is the old one and on the right is the new rotor with the old alluminum hat.
The removal of the hat is straight forward. All that has to be done is remove the 12 bolts that hold the hat. I am pleased with Baer though. They sent me everything that was needed to get the job done without having to call them and ask questions. The instructions are simple to understand and there was a diagram as well for the torque sequence when installing them hat.
Now please dot comment on teh last picture of the rotors. I know they are directional.
Enjoy and props to the people that followed through and made this part of the forum open.
why would you want them zinc plated? almost all of the rotor surface is in contact with the brake pads and would just wear off.
I'm also interested in the price on those rotors as well, to see where I am on my 2-pc setup vs. theirs.
Nice, I guess there really is no need for the zinc plating. Do you know how much these way with the hats installed?
Matt93SE: Do you happen to know the weight of a typical 13" Cobra Rotor?
Thanks!
JP
Thanks!
JP
How did he do that? Alot of work for maybe 1mm
Originally Posted by vsamoylov
yes these are used with the 300zx alluminum calipers. maxs made sure all of the rotor was in contact with the pads unlike wehre some people are not having full contact with the pads on the rotor. price for these is around $500.
He probably doesn't know as his kits don't utilize them
Thanks!
JP
Thanks!
JP
Thanks!
JP
Thanks!
JP
There's a VERY good reason for that. It's because the overhang is not even 1/3 that. I've sold probably 75+ sets. And I've read/heard/received next to none as for as fitment/usage issues.
I also see you guys like to avoid explaining how you "fixed" it.
uhh yes and nobody says anything about it either. 6mm is alot of unused pad material.
Mar 12, 2020 12:06 AM
i thought you had to wire 2 piece rotors also
uhhhhhh nooooo
