6th gen rims on 5th gen questions
Old Jul 1, 2006 | 09:44 AM
naxray's Avatar
Hi Folks,
I'm considering picking up a set of the '04-'05 rims for my 2K. They are the 6 spoke ones and are listed by the seller as 18X7.5 with a 40mm offset. I know I've seen some 5th gens with 6th gen rims here but wanted to ask if there are any issues with rubbing (I'm lowered on Maxspeeds)? How flush do these sit to the fenders? Is 235/40/18 the best tire size to go with? If you have this set up and have a pic or 2 to post that'd be most appreciated as well.
Thanks in advance for any and all help.
Old Jul 1, 2006 | 09:53 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
A 245/45/18 would actually be the ideal tire size (OEM spec). I have not heard of anyone having rubbing issues, so I don't think yours would either, particularly considering how your drop is not super-agressive. They don't sit flush with the fenders, you're still a good 1 - 2" from the fender with these wheels. IIRC, they are the same width as your current wheels.
Old Jul 1, 2006 | 10:25 AM
naxray's Avatar
Thanks Metal...I'm pretty sure the 2000 SE 17's are half an inch narrower at 7" wide. I was thinking the 235/40 would be closer to stock diameter and that would result in less of a speedo error.
Old Jul 1, 2006 | 12:32 PM
DrKlop's Avatar
Driving is the next best thing
235/40-18 on 18x7.5 with -40mm offset will not rub, however, it's not recommended to run these tires on 7.5 rims by most tire manufacturers. The closest to stock tire size that will fit on those rims is 225/45-18, you could also get 235/45-18 but I'm not sure if they will fit without rubbing.
These should help you make up your mind:
http://gs.tolan-hoechst.com/tirecalc.htm
http://forums.maxima.org/showthread.php?t=447370
Metal, I think you are confusing 245/45-18 with 245/45-17
Finkle
Sep 27, 2015 09:53 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
MikesChevelle
Aug 10, 2015 10:53 AM
