Shampooing the Interior Carpet
Old Jul 2, 2006 | 12:15 PM
NeeDog20's Avatar
Anybody ever try to take out the interior carpet of their 4th Gen Maxine and try to shampoo it with like a Rug Doctor??...It seems like i'm going to have to take apart my dashboard to do that...Anybody have any pictures of how to take apart their dash, OR remove and replace their interior carpet?...(its quite dirty with spilled soda and such everywhere from the previous owner)...Any help would be much appreciated...thanks
Old Jul 2, 2006 | 12:18 PM
MaximaSE96's Avatar
Maxima Owner
i just leavie it in the car...take out the seats......and use the hand held attachment to the particular shampoo machine i am using....or just use tide with color safe bleach in a bucket of hot water, scrub brush and shop vac
Old Jul 2, 2006 | 03:15 PM
dr-rjp's Avatar
Try using a steamer like the Shark in addition to Blue Coral Rug Cleaner, and a big, stiff brush.
Old Jul 2, 2006 | 07:44 PM
freshv6power's Avatar
6 parts water, 1 part woolite.
Old Jul 3, 2006 | 01:20 AM
semaj3708's Avatar
FEELS GOOD TO BE GANGSTA
If you remove the seats and center console, and don't mind a 3" cut under the dash down the center the whole thing will come out in one piece. Use a stiff nylon brush and some oxy clean(granular). Scrub the hell out of the carpet use a shop vac to get most of the moisture out and let air dry. I promise you it will turn out awsome. I have tried many other methods of cleaning, but this by far is the best/cheapest way to clean an auto carpet I've found. Here's a link for more info http://www.team-integra.net/sections...ArticleID=1024 and yes this is an acura thread, but take a close look at the pics!
Old Jul 3, 2006 | 01:30 AM
matty's Avatar
Pretty good stuff. I will be doing this next month for sure
-matt
Old Jul 4, 2006 | 03:46 AM
NeeDog20's Avatar
anybody ever try removing the dash....is it worth it? (i would also like to clean the dash and the vents since i haven't gotten a full service in like a year)
Old Jul 4, 2006 | 06:05 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Yes. Removed it once and will be removing it a second time. It's not the hardest thing, but there is a fair amount of work involved. For puposes of cleaning. it's really not worth it. So long as you have kept your air filter changed regularly, there should be no reason to have to do it.
Also, I recommend a steam cleaner over shampooing. Some OxyClean in the mix works WONDERS. You can rent one fro HD for about $30 or so. Well worth it.
Old Jul 11, 2006 | 06:25 AM
tarndt's Avatar
I have found that a bit of Spray Nine and water along with a ShopVac does the trick quite well and will not damage the colour in the carpet. I usually Scotch guard it after doing this. I worked in an auto detailing shop and we did this on most cars with nasty stains in the carpet.
Old Jul 11, 2006 | 07:21 AM
MaximaSE96's Avatar
Maxima Owner
for the vents if u ont have compressed air...but a couple of cans of the stuff u use on comuter keyboards and blow them out...i like to spray VinylX in the vents then blast them with air and a paintbrush
Old Jul 11, 2006 | 01:36 PM
97_Max's Avatar
I took mine to the car wash and did the hot shampoo and it works real good.
Old Jul 11, 2006 | 01:42 PM
SexyMaxima95's Avatar
don't the car washes charge alot to get the carpet shampoo
Old Jul 11, 2006 | 02:55 PM
Da_Shatterer's Avatar
How do you remove the dash?
Old Jul 11, 2006 | 03:41 PM
semaj3708's Avatar
1. Unplug Battery and let sit for 30 min.
2. Remove front seats.
3. Remove center console.
4. Remove/unplug ***see FSM***driver air bag(special tool needed Tamper Resistant Torx bit T50), steering column, spedo/radio cluster, glove box, knee bolster(plastic and metal).
5. Remove 2 screws in defog vents, 4 screws in radio compartment, 2 screw in glove box compartment, 2 screws in knee bolster, might be some others.
6. unplug passanger air bag.
7. Remove dash.
Took me about 2 hours removal and instal, but then I've done quite a few times.
Old Jul 11, 2006 | 04:31 PM
RockfordMax's Avatar
Back from the dead
for the Spray Nine, I used that at Lexus and it cleans EVERYTHING off of EVERYTHING.... Where do you get yours, I've been looking around for a place to get it since I quit.
97_Max's Avatar
No I had to do it myslef it only cost me $1.00
Old Jul 11, 2006 | 04:56 PM
RedfoxXx's Avatar
hand tools are youre freind
Old Jul 11, 2006 | 05:03 PM
4. Remove/unplug ***see FSM***driver air bag(special tool needed Tamper Resistant Torx bit T10), steering column, spedo/radio cluster, glove box, knee bolster(plastic and metal).
7. Remove dash.
Thanks alot for the detailed info.
Old Jul 11, 2006 | 10:12 PM
NYC32798's Avatar
My parents have a huge washing machine so I just throw my floor mats in there and it works better than any shampoo or stain remover i've ever used. Doesn't screw up the mats or the machine. The mats come out looking brand new. It even got out a few deep stains I had trouble getting out.
Old Jul 11, 2006 | 11:27 PM
96blkonblkse's Avatar
when you clean the carpets when there in the car, make sure you let it air out, put all the windows down, sunroof open and let it sit for awhile, vacuum out as much water as you can get, sometimes i use a old towel and just dab the carpet to get all the liquid out, if you dont let it air you your car will smell musty inside, its not very pleasent. oxyclean works wonders on stains, and doenst have any after smell, like some cleaners.
Old Jul 12, 2006 | 04:18 AM
MaximaSE96's Avatar
Maxima Owner
word i just got some Oxyclean too..i think when i move into my new house i am gonna tear the interior apart and give it an awesome cleaning .....do do vacuums and wipe downs every week which reallllly helps keep it nice...but there are those hard t get spots and just a feeling of a clean car is fabulous
Old Jul 12, 2006 | 04:57 AM
tarndt's Avatar
I get a 4 Litre bottle at Candian Tire for a little under $20 (I imagine you would be able to get it at department stores such as Wal-Mart and Home Depot as well).
Old Jul 12, 2006 | 05:16 AM
Stealth Max's Avatar
Here is the link for buying Spray Nine.
http://www.spraynine.com/
Old Jul 12, 2006 | 08:02 AM
975spdmax's Avatar
at my work we do it but i think its $60. and wouldn't it be easier to leave the carpet in and do it?
Old Jul 12, 2006 | 07:08 PM
grandmastr's Avatar
I got some stuff from lowes, high traffic carpet clearner, I soaked my interior with this stuff,and got a towel and scrubbed for like 30 mins than I got a regular garden hose on a low setting, sprayed everythign down while having the wet-dry vac on next to it to suck up the water.
I had about 25 gallons of water that was pitch black. Nasty, and now I have no smell of smoke(previous owner was a smoker). Car has no orders and everything in the car is much cleaner and brighter.
Make sure to soak up all the water and leave your windows a hair down to get the moisture out. DO NOT SPRAY NEAR THE DASHBOARD.
Old Jul 13, 2006 | 04:04 AM
ChristheNite
Anyone else tried the washing machine? I'm kinda interested in giving this a go...
Old Jul 13, 2006 | 07:59 AM
alleydawg6's Avatar
Livin dreams thru his Maxima
-matt
yo matt were u at the meet in west orange?
Old Jul 13, 2006 | 01:07 PM
Polarisdb's Avatar
We used a Bissell Green Machine on my Acura before we sold it and it did an amazing job. It even got soda stains out of the seats that had been there for quite some time.
Old Jul 13, 2006 | 03:00 PM
semaj3708's Avatar
Man you've got *****!
Old Jul 18, 2006 | 08:25 AM
NeeDog20's Avatar
Anybody have a link to the Factory Service Manual?...(need to remove the driver side air bag)...
Fbana41
Aug 29, 2016 12:18 PM
BobTX10
Oct 7, 2015 08:43 AM
sliptap
Sep 30, 2015 05:57 AM
worldwiderecognized
Sep 24, 2015 06:56 PM
