Shampooing the Interior Carpet
![](https://maxima.org/forums/images/smilies/support.gif)
Anybody ever try to take out the interior carpet of their 4th Gen Maxine and try to shampoo it with like a Rug Doctor??...It seems like i'm going to have to take apart my dashboard to do that...Anybody have any pictures of how to take apart their dash, OR remove and replace their interior carpet?...(its quite dirty with spilled soda and such everywhere from the previous owner)...Any help would be much appreciated...thanks
i just leavie it in the car...take out the seats......and use the hand held attachment to the particular shampoo machine i am using....or just use tide with color safe bleach in a bucket of hot water, scrub brush and shop vac
If you remove the seats and center console, and don't mind a 3" cut under the dash down the center the whole thing will come out in one piece. Use a stiff nylon brush and some oxy clean(granular). Scrub the hell out of the carpet use a shop vac to get most of the moisture out and let air dry. I promise you it will turn out awsome. I have tried many other methods of cleaning, but this by far is the best/cheapest way to clean an auto carpet I've found. Here's a link for more info http://www.team-integra.net/sections...ArticleID=1024 and yes this is an acura thread, but take a close look at the pics!
Originally Posted by NeeDog20
anybody ever try removing the dash....is it worth it? (i would also like to clean the dash and the vents since i haven't gotten a full service in like a year)
Also, I recommend a steam cleaner over shampooing. Some OxyClean in the mix works WONDERS. You can rent one fro HD for about $30 or so. Well worth it.
I have found that a bit of Spray Nine and water along with a ShopVac does the trick quite well and will not damage the colour in the carpet. I usually Scotch guard it after doing this. I worked in an auto detailing shop and we did this on most cars with nasty stains in the carpet.
Originally Posted by Da_Shatterer
How do you remove the dash?
2. Remove front seats.
3. Remove center console.
4. Remove/unplug ***see FSM***driver air bag(special tool needed Tamper Resistant Torx bit T50), steering column, spedo/radio cluster, glove box, knee bolster(plastic and metal).
5. Remove 2 screws in defog vents, 4 screws in radio compartment, 2 screw in glove box compartment, 2 screws in knee bolster, might be some others.
6. unplug passanger air bag.
7. Remove dash.
Took me about 2 hours removal and instal, but then I've done quite a few times.
Originally Posted by semaj3708
1. Unplug Battery and let sit for 30 min.
4. Remove/unplug ***see FSM***driver air bag(special tool needed Tamper Resistant Torx bit T10), steering column, spedo/radio cluster, glove box, knee bolster(plastic and metal).
7. Remove dash.
7. Remove dash.
My parents have a huge washing machine so I just throw my floor mats in there and it works better than any shampoo or stain remover i've ever used. Doesn't screw up the mats or the machine. The mats come out looking brand new. It even got out a few deep stains I had trouble getting out.
when you clean the carpets when there in the car, make sure you let it air out, put all the windows down, sunroof open and let it sit for awhile, vacuum out as much water as you can get, sometimes i use a old towel and just dab the carpet to get all the liquid out, if you dont let it air you your car will smell musty inside, its not very pleasent. oxyclean works wonders on stains, and doenst have any after smell, like some cleaners.
I got some stuff from lowes, high traffic carpet clearner, I soaked my interior with this stuff,and got a towel and scrubbed for like 30 mins than I got a regular garden hose on a low setting, sprayed everythign down while having the wet-dry vac on next to it to suck up the water.
I had about 25 gallons of water that was pitch black. Nasty, and now I have no smell of smoke(previous owner was a smoker). Car has no orders and everything in the car is much cleaner and brighter.
Make sure to soak up all the water and leave your windows a hair down to get the moisture out. DO NOT SPRAY NEAR THE DASHBOARD.
We used a Bissell Green Machine on my Acura before we sold it and it did an amazing job. It even got soda stains out of the seats that had been there for quite some time.
CAN-Toronto 97 SE BLACK w/ BLACK. PART OUT.
worldwiderecognized
09-24-2015 06:56 PM
