found feature on accident
Old Jul 17, 2006 | 12:21 AM
alextothestars's Avatar
who knew that theres a safety lock in the trunk of the car? i was moving a week ago and i accidentally triggered the safety lock (trunk was full of items) and had to take the back seat out to get back in to the trunk (the trunk unlock mechanism had no effect on the trunk with the safety lock down)!
heh; i also replaced the rear drivers side window motivator and motor. the replacement just broke somehow today when i was rolling it up. wtf. i know i bought the car for $2k and i love it, but this damn thing is nickel and diming me to death! at least the fixes are usually simple and work...most of the time.
Old Jul 17, 2006 | 04:11 AM
Greeny's Avatar
¯\(°_o)/¯
What is a motivator?
Old Jul 17, 2006 | 04:54 AM
Zero Deuce SE's Avatar
Must be something that encourages the window to move. I'm sure he meant regulator.
Old Jul 17, 2006 | 05:21 AM
Greeny's Avatar
¯\(°_o)/¯
Duh,i know what he meant..Just messing with him..
Old Jul 17, 2006 | 05:35 AM
jadegreenmax's Avatar
That trunk safety switch just stops the trunk release button from working, it still opens if you use the MAIN key. The valet key won't open it. The trunk lock is there so you can drop the car off somewhere, and give the person you are leaving it with the valet key and then they can't get into the glove compartment or trunk with your key, and then if you use the trunk lock, they can't open the trunk with the release button.
Old Jul 17, 2006 | 05:41 AM
grinder's Avatar
From what i can tell, if you get your key copied it won't work in the doors or the trunk eather
Old Jul 17, 2006 | 05:46 AM
grinder's Avatar
i have two maximas, 92 gxe auto, and 89 se fully loaded 5spd, both of them i only have a copied key for them and the key won't work in the door or the trunk and is hard to use in the ignition too
Old Jul 17, 2006 | 06:11 AM
Cliff Clavin's Avatar
Way out West
my copied key works on the trunk and glove box
someone probably copied the valet key for your cars or they went to a bad locksmith.
Old Jul 17, 2006 | 06:24 AM
mrkanda's Avatar
Taking my Maxima to the Max!
That's probably because the person who made your copies did not get a perfect or close to perfect match. You should just take them back and have them regrind the copies so they are closer to the Master. You should be able to hold up the copies to the Master and see any differences that may be causing the difficulty.
Old Jul 17, 2006 | 10:14 AM
the copied key shouldn't have trouble opening the door, but since it has trouble in the ign., it sounds like it's just a bad copy.
Old Jul 17, 2006 | 02:45 PM
grinder's Avatar
both of the cars keys were copied onto house key blanks, don't have the master keys
Old Jul 17, 2006 | 02:49 PM
grinder's Avatar
is there any way i can get a new key from a nissan dealership
Old Jul 18, 2006 | 06:06 AM
you should be able to as long as you show them proof of ownership.
Old Jul 18, 2006 | 06:22 AM
grinder's Avatar
so all i will need is a title and my id?
Old Jul 18, 2006 | 07:43 AM
that should be all you need, iirc
Old Jul 18, 2006 | 07:46 AM
grinder's Avatar
thanks for the info jadegreenmax, a new key will help out alot
Old Jul 18, 2006 | 08:16 AM
You should be able to get some made using the VIN unless you know the key code to give them.
Old Jul 18, 2006 | 08:29 AM
grinder's Avatar
where do you get the key code?
Old Jul 18, 2006 | 08:35 AM
The key code tag comes with the car when it's new. The original owner is supposed to record the numbers and remove the tag from the keys. If you bought the car used you would be extremely lucky to find the code unless the previous owner(s) left it inside the car somewhere like the glovebox. The dealer should be able to find the key code using the VIN so you don't need to worry about finding it on your own.
Old Jul 18, 2006 | 10:39 AM
mszilves's Avatar
Do you have pics of the location of the safety lock switch? Where exactly is it...
Old Jul 18, 2006 | 10:53 AM
Greeny's Avatar
¯\(°_o)/¯
Pop your trunk and look under the lock mechanism on the body of the car[not the trunk lid] There will be a square hole with a little slider type lever inside the hole..The up position is normal,down is safety position...
I think?
Old Jul 18, 2006 | 10:58 AM
Michael's Avatar
Back in a 3rd Gen.
sorry to inform you guys but you will be out of luck if you try to get a key cut with the VIN. They started keeping those records in late 94 I believe. Everyone I know that has tried (including me) to get a key cut with the vin has not been able to. So far I havent seen anyone come up with a key code either. I saw it mentioned and some people said it was in the glove box but no one has found it. It is probably in the sales pack you get when you buy the car but not many people keep that stuff.
Old Jul 18, 2006 | 11:12 AM
I was lucky, when I took over the car the original owner still had the Master Key, the spare, the valet key, and the key code plate all on the same ring.
Old Jul 18, 2006 | 12:31 PM
JRS89MAX's Avatar
Im on my 3rd copied key. Broke the other 2 while sitting on them while driving a hi-lo. (stupid keychains that go on belt buckle)3rd key works on all doors, trunk and ignition.Then I have my spare that i made.Didnt work on nothing.Took a small file. Filed lightly on teeth. Opens pasenger door, trunk and ignition.
Old Jul 18, 2006 | 04:43 PM
grinder's Avatar
would i still be able to get a key made without the key code?
Old Jul 18, 2006 | 04:59 PM
Michael's Avatar
Back in a 3rd Gen.
huh...did you read my post?
You can always get a key made by making a copy of an existing key but you just cant get a new one cut by the VIN.
If you go to a good lock smith and not walmart or a hardware store you will be able to get a good copy made even if your key is worn. Heck I had a locksmith make me a master key with a valet key. I locked my keys in the trunk of my old MR2 but luckily I had my valet key in my walet. Well that wouldnt open the trunk so I went to a locksmith and they knew exactly what the difference was and made a perfect key that worked the trunk, door and ignition.
Not sure if there are many quality locksmiths left though.
Old Jul 18, 2006 | 08:13 PM
grinder's Avatar
basicly i wanted to know if i could still get one from nissan, which i belive the answer is no.
the only decent locksmith (or real city) around here is about two hours drive from here so i was trying to avoid that if possible.
Old Jul 18, 2006 | 08:19 PM
Michael's Avatar
Back in a 3rd Gen.
you can buy new blanks from them but thats about it. Most of the Nissan dealers I know of have a key cutter that goes by a code...without the code they can do nothing.
But like I said you can buy a nice blank key with the big black plastic that says Nissan on it and take it to a locksmith or any place that makes keys and have a copy made.
Old Jul 18, 2006 | 08:33 PM
grinder's Avatar
cool, thanks for the info. that saved me alot of hassle more than likely
Old Jul 19, 2006 | 12:54 AM
safety lock keeps locking on me! did it again today! i got a damn lemon.
Old Jul 19, 2006 | 03:31 AM
Phoenix's Avatar
Lives in a Maxima
IIRC, the key code is stamped onto the ignition cylinder. It should also be stamped onto the door lock cylinders. I'm pretty sure it was on my 90 240SX so logic would dictate that it would be the same on our cars, since they're from the same era. But since when did logic mean anything?
Otherwise, if you have the original key ring from the dealer, it will have a little 5mm by 20mm tag affixed to it with the key code stamped onto it. I was lucky with my old 240 and had both original keys, the valet key, and the key code tag.
As far as the trunk safety lock goes, I found that a while ago by accident too. Of course, I was reading the manual when I happened upon it.
Old Jul 19, 2006 | 04:43 AM
internetautomar's Avatar
mod or sell?
my dealer just cut mine on a generic blank
but it was by the code I gave them.
and they also told me that they can't go back farther than 94 from the VIN
Old Jul 19, 2006 | 06:20 AM
Michael's Avatar
Back in a 3rd Gen.
yeah they want top dollar for those original style blanks. I got a couple for my old Altima I had and I think I paid like $5 or more for just the blank.
So where did you get the code then.
Old Jul 19, 2006 | 07:34 PM
mod or sell?
1. it was only $5 cut by the code
2. it was in the glovebox on a sticker, same as my current one is.
Fbana41
Aug 29, 2016 12:18 PM
D Mason
Jun 21, 2016 04:43 AM
MaxLvr21
Oct 17, 2015 12:11 PM
BobTX10
Oct 7, 2015 08:43 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
