Berk intake, filter mount loose?
Old Aug 8, 2006 | 08:19 PM
AscendantMax's Avatar
Well, I was driving to grab some lunch for a buddy of mine earlier today. While on the freeway on-ramp, I heard a slight rattling sound each time I pressed the throttle. But the sound went away while I was at cruising speed. Got to the restaurant, and the noise came back when I was driving up the driveway. So, I popped the hood, and looked around. Found out the bolt that holds the last section of the Berk intake came loose (picture below). How the hell did it come loose? The only thing I can think of is that the rubber couplings are not allowing the engine to move whenever I'm under heavy thottle etc. The bolt was tight when I installed it a few weeks ago. Anyhow, I tightened the bolt, and the noise is now gone. Anyone else have this issue?
Old Aug 8, 2006 | 08:24 PM
jsmithsole's Avatar
*moderator*
Yup, mine has always come loose. I just check it every other week or so to make sure. I told Bryan from Berk about this when I did the test install for the intake a long while back. I guess he never changed anything to fix the problem...
Old Aug 8, 2006 | 08:29 PM
Does it need to be bolted down? He should have gotten the issue resolved after you told him IMO...
Old Aug 9, 2006 | 12:59 AM
MisterSparkle's Avatar
have you guys tried the tread locking glue?
Old Aug 9, 2006 | 03:49 AM
ramberg's Avatar
GrandPa
That sucks. Some members have had the same problem with the Injen. Chernmax came up with a fix.
Old Aug 9, 2006 | 07:35 AM
What did he do to fix it?
Old Aug 9, 2006 | 01:09 PM
its funnie...once you see it i think you'll laugh and give him props for it...lolxz...he's a genious!
Old Aug 9, 2006 | 01:27 PM
I'm thinking of getting a rubber washer, and put it between the mount and the the car. it should absorb the vibrations and allow some movement...hopefully preventing the bolt from coming loose.
Old Aug 9, 2006 | 01:34 PM
kroyo_MAX's Avatar
^ --- that's a good idea... anytime i slightly accelerate there's is a creaking noise. maybe the rubber washer idea would be the solution..
Old Aug 9, 2006 | 10:09 PM
you have the berk too?
Old Aug 9, 2006 | 10:26 PM
jsmithsole's Avatar
*moderator*
I never bothered to try and fix it, it only comes loose every few months and I'm under the hood messing with somethng or cleaning every couple of weeks anyways...
Old Aug 10, 2006 | 02:19 AM
kroyo_MAX's Avatar
yeah..
...sorry.. i forgot to mention that..
Old Aug 14, 2006 | 11:10 PM
ramberg's Avatar
GrandPa
Send him a PM.
Old Aug 14, 2006 | 11:18 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Gordon, you should pick up a locking nut from Lowe's, Home Depot, or any other hardware store. Should keep from coming loose once that's installed.
bumpypickle
Sep 20, 2015 08:22 AM
Maxboy23
Sep 9, 2015 10:37 AM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
