Car Jerks, what could be wrong?
Old Aug 9, 2006 | 06:57 PM
ancientwiseone's Avatar
Hi I need some help. My 99 maxima started to idle really rough and it jerks at idle. Once I accerlerate, the car would jerk a bit and the rpm would drop a bit. This problem goes on all the time, its not like an off and on thing. The next thing is that when I reverse to get into my parking space, the car seems to jerk and idle really low, then it would like almost stall out. During that point, i would see the oil gauge light blink couple times. What can this problem be? I would like to get it fixed asap. Thanks alot guys
Old Aug 9, 2006 | 07:24 PM
Black Maxima
Coil packs?
Old Aug 9, 2006 | 08:00 PM
99se5speed's Avatar
SHIFT_up
^ speaks the truth!!
Old Aug 9, 2006 | 08:20 PM
WhiteMaxima9600's Avatar
coil packs, plugs, fuel filter, dirty iac, dirty throttle body, those should be a good starting point......... good luck!
Old Aug 9, 2006 | 08:26 PM
adithius's Avatar
The problem will progressively get worse. I changed my coil packs and no more problems. Plus the car runs a lot better.
Old Aug 10, 2006 | 12:54 AM
i have a 99 max, and I did replace all 6 coils last year.
Old Aug 10, 2006 | 04:02 AM
PLUMMAXSE's Avatar
Get you some new or used coil packs, ASAP! You need to replace all 6 to get your max back to smooth running. You have 1 pack that is dead right now. That's where the bucking and low idle is coming from. 1999 Max coil packs suck
Old Aug 10, 2006 | 05:35 AM
willard00's Avatar
same with me...how many miles u got? i replaced mine around 115000
Old Aug 10, 2006 | 06:50 AM
5.0_junkie's Avatar
Mine are original with 170,000 and still running strong I guess I got lucky so far.
Old Aug 10, 2006 | 07:28 AM
I replaced all 6 of my coils last year already. The next thing is that wouldn't it trigger a code if my coil went bad?
Old Aug 10, 2006 | 07:31 AM
nearthisbridge's Avatar
You'd likely get a misfire code, but personally it took me 2 weeks of driving with a failing coil before I got the CEL.
As for your problem, the post a few above is on the right track. Check your filters (air, fuel), spark plugs, clean TB & IACV, etc.
Old Aug 10, 2006 | 08:39 AM
dgeesaman's Avatar
Maintenance Monster
Even though you're calling us "car jerks", I'm still going to suggest checking the coil packs
Old Aug 10, 2006 | 10:23 AM
95mtlMAXSE's Avatar
shift_Puff
hahaha at first i thought the same thing
mines doing the same, let's check the group deals shall we and see what's available. I need coils and a whole new exhaust line. Talk about loss of power, civics beat me My 95 auto, couldn't be better, i might switch them out from one to the other
Old Aug 10, 2006 | 10:28 AM
willard00's Avatar
not nessacarilly(spelled that horribly.)....took me like at least a month to finally get a code.
Lakersallday24
Jun 16, 2019 01:35 AM
kingw323
20
Oct 21, 2015 08:36 AM
laparka66
Aug 6, 2015 09:36 AM
maxima297
Aug 3, 2015 12:50 PM
