00' engine misfire
Old Aug 19, 2006 | 08:23 AM
mooze's Avatar
00' engine misfire
having a misfire. have changed the coils spark plugs and replaced egr. what else could be causing this?
Old Aug 19, 2006 | 08:25 AM
upstatemax's Avatar
Are all of the coils snapped down all the way?
I had one loose one and it was causing a misfire. pushed it down really hard so it finally snapped down... No problem since.
Old Aug 19, 2006 | 08:31 AM
mooze's Avatar
yep. all down
Old Aug 19, 2006 | 08:40 AM
mooze's Avatar
any1 else know anything
Old Aug 19, 2006 | 12:52 PM
StreetzINC's Avatar
Mooze I have a 00 Maxima 5 Spd with the same exact problem.Look @ your front Cat when the car is warmed up and see if it is glowing red inside. If it is we have the same exact problem. Lets get this solved together!!
Old Aug 21, 2006 | 01:16 PM
sjcrew3's Avatar
i have 2000 max se 5 spd. same problems as you guys. my engine was misfire a lot in the beginning when i bought half year ago. i changed the spark plug, MAF, misfiring toned a lot. but there is still a little left. somebody suggests i should changes my coils too. is that way to go for me? thank for any suggestion.
Old Aug 22, 2006 | 05:57 PM
armysoldier's Avatar
I also have a 5 spd. '02 and I acutally I had to change my coils because of multi-misfire... I could only order 2 (1 front and 1 rear) since it is still kinda new... but by looking at which spark plugs were rounded (there were three) I kinda guessed which coils were bad... but WARNING buying coils are rather pricey I spent close to $200 for a front and rear one... if you're having misfires though 9 times out of 10 the coil and sensor are bad and replacing them is the only way to go.
Old Aug 23, 2006 | 10:17 AM
sjcrew3's Avatar
thanks for the information. you are saying replacing the sensors. what sensors are you talking?? thanks
Old Aug 31, 2006 | 07:37 PM
yeah you'll have to replace the whole set ignition coils/sensors (a rather pricey move) best way to find out which ones are bad is by looking at your spark plugs (if you haven't already changed them)... if they are rounded and the others are sharp tipped (at least mine were) the rounded ones were the misfires... i used to have the this problem and I could only order two coil sets (1 front. 1 rear) for my 2k SE and it ran me $200 but the problem was solved...
Old Aug 31, 2006 | 08:45 PM
Albi860's Avatar
Your MAF could be bad and may need to change it's a major problem with the 5th and 5.5 generation max
shilov
Feb 19, 2024 09:40 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
ballerchris510
Sep 11, 2015 05:29 PM
