Hey..just got my intake off ebay..
i got this one http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
- what are these cheap blue plastic things? ...
-and the hoses' heads are bigger than the holes on the middle pipe... is that ok?...or am i better off with using the stock hoses and all.?
- there's nothing that i'm missing right ?
Originally Posted by Fre$h_TurK
no instructions...... i know what to do with it but im asking some questions
Relax,
Check the How to's, & you'll find out or look at some pics
So much drama on the org....
Anyway Turk i know your very far from having a Injen intake but this should still help you in changing yours since your e-bay one is probably a replica...This how-to is for the 5th gen but you should be fine.
http://www.vqpower.com/v2/modules.ph...showpage&pid=9
Sorry to tell you this, but you bought one of the "wrong" intakes. It's "wrong" b/c it has 4 nipples coming out of the pipe, it's only suppose to have 3. You can just cap one of the little ones off and you would be okay.
Originally Posted by EnervinE
Never buy something you don't know how to install...
I agree.
and Dang dude no need to snap just trying to help das all if you didnt want anyone saying anything shouldnt have posted. Reguardless no need for instructions just take your stock one off and see where everything goes take pictures if you need to. It reletively easy just use your imagination.
gtfo ahole....i dont gotta ask u what to do
Shut the **** up MAN!
you have ZERO knowledge in the automotive world. If you had any common sense you would know NOT to use those hoses for the intake. INTAKE = AIR
ENGINE is nothing but a big vac. THEREFORE those condom like hoses arent going to go jack. For a working boy you shouldn't need to buy crap from ebay. You spend the money and do it right the 1st time.
Turks, I understand why you are frustrated, they are giving you BS replies so you do like wise. I'll try to help you as much as I can:
Take out the four bolts holding the MAF to the upper portion of the airbox with a 10mm wrench. With the upper portion out, take the stock air filter out and you should see 3 bolts holding it the bottom airbox. Take these out with a 10mm socket. Then you should be able to pull out the MAF, be very gentle and carefull. Unclamp the two big hoses and take them off the stock midpipe, you can gently pull out that little hose. Now unscrew the clamp holding the midpipe to the throttle body. Now put the blue coupler into the TB, put the new midpipe in the other end. Plug in the 3 hoses, use the other coupler to connect the pipe with the MAF. Bolt the MAF adapter to the MAF and install the filter. Hope this helps.
This was pretty helpful b/c it has pics: http://www.brianv.net/mods/filter/
^ LOL ROFL OMG
Duck tape FTW??????? OMGZORS!
I assume you haven't read any of his other threads. Anyway yeah go ahead do it that way duck tape the bracket because you need to make it air tight. You should use black tape therefore it wouldn't look as stupid as it does....
1. Use whichever hoses fit best, and use the clamps from your stock hoses to hold them onto the nipples on the midpipe.
2. Cheap couplers (the blue things) are not the best things to have, but they'll work fine. Just don't manhandle them, don't spray strong solvents (like brake cleaner) on them a lot, and check them for cracking or leaks every couple of months.
3. I could be wrong, but it doesn't look like there's anywhere to screw in your IAT sensor (currently fastened to your airbox with 2 screws). If that's the case, no big deal. Just tie it up out of the way and tuck it in somewhere near the filter.
4. Be prepared for some slight losses in torque and throttle response at certain RPMs. Intakes don't do much on these cars without tuning.
maxima297
Sep 30, 2015 03:32 PM
I hope you aren't thinking that that link was mines. I got it from the Stickies.
