E-manage- Blue vs Ultimate- differences?
Old Sep 11, 2006 | 06:02 AM
RichMax's Avatar
Boosted like Snipes tax refund
I am looking for the differences between the two platforms. Based on what I have read, the only thing an Ultimate has over the Blue is datalogging capabilities, connectivity to a laptop via USB, and improved injector control... what else am I missing? The Blue ignition and injector harnesses seem to add all the ignition and injector functionality someone would need for an F/I application... do they?
Greddy's website doesn't seem to detail these too well.
Old Sep 11, 2006 | 07:20 AM
matty's Avatar
http://www.mohdparts.com/emanage/ult...res/index.html
Alot more maps avaiable, Rev limit extender, A/F Target Map, NVCS map for controlling 00VI or MEVI, The ability to use Cam and Crank Signals (well not yet) Abilitity to Adjust Lag time on Injectors, Scaling injectors a bit more easier.
-matt
Old Sep 11, 2006 | 08:05 AM
SPiG's Avatar
SomePsychoGuy
Ultimate:
Better injector control and scalling, completely control pulsewidth
Can read and advance timing (with Cranks sensors and v2.0beta)
2 step rev limit for drag racing
Data logging
Run without a MAF, and just use the pressure sensor
Blue:
Cheaper
Can hook up profec E01
Both:
Extending Rev limit through adding fuel past 6500rpm
retard timing
Adjust MAF voltage and some injector control
with a $10 GM solenoid, you can have a fully adjustible boost controller
Old Sep 11, 2006 | 09:08 AM
DandyMax's Avatar
3.5 in the works
There is a world of difference in the capabilities between the 2. The best thing to do is download the manuals off the mohdparts site. Reading through them will give you a much better idea of what all the EU can do over the Blue.
Old Sep 11, 2006 | 01:38 PM
Latinmax2
Originally Posted by SPiG
Both:
I can extend the rev limit with my blue?!?! How?... I wanna know... please.
Old Sep 11, 2006 | 04:41 PM
SPiG's Avatar
SomePsychoGuy
I think you just add fuel after the stock rev limit at 6500. Since you are boosted you might want to pay attention to timing and be careful once you are above the stock cut. The RLC map really isn't necessary.
http://forums.maxima.org/showpost.ph...&postcount=206
Old Sep 11, 2006 | 09:33 PM
SPiG's Avatar
SomePsychoGuy
Correction: No one has gotten the extended rev cut to work on blue. You do not need the RLC map, but there might be something else that holds blue back.
Old Sep 11, 2006 | 10:05 PM
maxgtr2000's Avatar
KH3 by popular demand
I think the Ultimate is for the serious enthusiast, aka a track maxima/racing. Blue in my opinion is just for the daily driver. Comparing Ultimate to blue is like Playstation 1 vs Playstation 3 imo.
Old Sep 11, 2006 | 10:22 PM
DandyMax's Avatar
3.5 in the works
In terms of features and function, yes the comparison is valid but I wouldn't say the EU is just for a track car. It depends on the setup, but it could be extremely useful for a street car as well, especially a boosted one.
It allows you to easily run much larger injectors without needing a FMU, run a pressure sensor instead of a MAF, or possibly negate the need to get a higher reading MAF (ie -airflow clamps if the stock one is maxed out), retard timing and add fuel, it could be used as a boost controller, not to mention all the datalogging etc, etc.. the list goes on and on, I'm probably forgetting something obvious.
IMO those kinds of things are universally useful, not just at the track.
Old Sep 12, 2006 | 07:09 AM
matty's Avatar
Also open up your MEVI, or 00VI with a built in RPM switch
-matt
Old Sep 14, 2006 | 12:46 PM
glenmoormax's Avatar
10 psi
I have been following you on this for awhile and some I still don't understand, and I am sure when I get it (when it officially releases) I will learn a lot more.
Is it easier to have it and navigate through the options etc or is it a PITA, I am an average computer user, with pretty decent knowledge of our motors, just hoping I don't get it and get flustered because I can't figure the SOB out..
Old Sep 14, 2006 | 12:57 PM
LatinMax's Avatar
I am confussed also. So you CAN raise the rev limit on the E blue?
Old Sep 14, 2006 | 01:01 PM
Nealoc187's Avatar
SLOW
No you cannot raise the rev limiter with the blue according to what we know right now and our analysis of how the blue works.
Old Sep 14, 2006 | 09:09 PM
DandyMax's Avatar
3.5 in the works
The software is actually quite user-friendly if you ask me. I'm always willing to respond to questions though if you need help...
Old Feb 9, 2007 | 05:11 PM
streetzlegend's Avatar
does the blue have a built in rpm switch as well?
Old Feb 23, 2007 | 07:59 AM
Zero-K's Avatar
VQ30DET
no it doesn't
Old Feb 23, 2007 | 08:05 AM
Kevlo911's Avatar
Kevlo for President
Blue has vtec switch IIRC so it can control a VI
tarun900
19
Dec 20, 2021 06:57 PM
doctorpullit
Dec 12, 2015 09:39 AM
MaxLvr21
Oct 17, 2015 12:11 PM
Stagnet04
Oct 11, 2015 08:16 PM
BobTX10
Oct 7, 2015 08:43 AM
