Oil pressure sensor/sender questions...
Old Sep 25, 2006 | 12:22 PM
RichMax's Avatar
Boosted like Snipes tax refund
I noted this set of questions hasn't EXACTLY been posted before...
I see teflon paste should be applied to the T-fitting for the oil line. My questions, never having used the stuff before, are as follows:
Do I coat ALLL the threads of the fitting with the paste, or just the ones still exposed (the excess thread, I suppose)
Do I use Teflon paste where the fitting threads into the oil pan/engine block? (I assume not because if it comes off into the block at some later point, I am MORE than screwed)...
Last question... is the orientation of the oil pressure sensor critical? If my T is actually facing the ground (i.e., the OPS is actually threaded directly UP into the T) do I have a problem? If so, what kind of problems can I expect from it being oriented that way?
Old Sep 25, 2006 | 03:45 PM
Coat/wrap all the threads. Start coating/wrapping the threads 1/4 inch up the thread from the tip, this will ensure it won't get mixed in the oil. Just use common sense and know/estimate how much of the thread will be "threaded" and not exposed to the oil and you'll be fine. Wrapping the exposed threads is pretty much useless; if the oil gets that far, you have a leak. You want to prevent the leak, not stop it.
See above
I don't know for sure, but I seriously doubt it. It's just a sensor. Most sensors are not orientation specific. The only slightly potential problem I could see is if you ran over something and it snagged the OPS which is dangling down. That would be very BAAAD.
Are you not able to thread the "T" so the sensor is parallel to the ground?
Old Sep 27, 2006 | 04:12 AM
RichMax's Avatar
How much leaking (if any) should you expect in roughly 2 min of operation? I assume none. let me know...
Old Sep 27, 2006 | 07:15 AM
There should not be any leaking. If you don't have a leak after two minutes, you're not out of the woods just yet. The oil is not yet at full operating temperature (maximum viscosity isn't reached yet). I suggest you double check if you have a leak or not after you've fully installed the SC and gone for a decent drive. Then get under the car again, check for leaks, recheck belt tension, etc etc. With the car on, make sure the belt is tracking properly.
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
