Ebay Angel Eye burnt out - 1 on each side?
Old Oct 9, 2006 | 08:46 PM
MaxTooNice's Avatar
I'm not sure what the problem is, but I installed these along with my HID's and they were working fine for a couple of weeks. Then the outer ring on my drivers side goes out. A couple of days later the outer ring on my passenger side goes out. I checked the wiring, and everything looked fine and secure.
I'm not sure what the problem can be other than the led itself that burnt out. But I thought LEDs were made to last thousands of hours. I'll be looking into it more when I have some time this week, but I was wondering has anybody else ran into this or a similar problem. Any advice or suggestions would be greatly appreciated.
Old Oct 10, 2006 | 08:05 AM
2kSC's Avatar
those LES suck, u can take apart the headlight and replace them...or just cut the wires and try not to pose as a bmw....
Old Oct 10, 2006 | 10:10 AM
trigger005's Avatar
thats just their life span
members have had same issue in the past
did u do research before u bought em?
Old Oct 10, 2006 | 02:25 PM
808MAX-SPEC's Avatar
I know you said they're LEDs but they look like CCFLs.
Old Oct 10, 2006 | 04:18 PM
xnyc's Avatar
nah theyre leds. just take them out and put new leds in them. get some higher mcd rated leds so theyre brighter. theres a writeup somewhere i think by drklops
Old Oct 10, 2006 | 04:48 PM
MaxTooNice's Avatar
I was looking for suggestions to fix the LEDs, not opinions on the mod but thanks for being a *****.
Old Oct 10, 2006 | 04:50 PM
MaxTooNice's Avatar
if I switch them out do you think I'll run into the same problem again? Damn I thought LEDs lasted for a long time
Old Oct 11, 2006 | 05:51 AM
M1RAG3's Avatar
from my experience with my projector headlights, which use LEDs for the angel eyes, LEDs are very unreliable. Shortly after one went...so did two of the others, all in a span of 2 weeks. My opinion is that replacing the LEDs again will probably solve the problem for awhile, but they are likely to blow again. I couldnt be bothered opening up my headlights multiple times so I just gave up on the angel eyes all together.
Old Oct 11, 2006 | 10:28 AM
It could be a wiring issue that's causing the LEDs to blow. And yes they are supposed to last.
Old Oct 11, 2006 | 10:33 AM
MaxTooNice's Avatar
Do you have any suggestions? I just spliced to LED wires into the wires for the running lights.
Old Oct 11, 2006 | 11:01 AM
That should be fine. Not sure why they blew. The manufacture might have used crappy LEDs or the ones you have are just a bad batch. Might be a good idea to replace all the LEDs at the same time. You can get 50 pieces 5mm LEDs at 20,000 mcds and up for about $15-20 off eBay.
Mar 12, 2020 12:06 AM
londonflu
40
Sep 25, 2015 09:11 AM
Colossus
Sep 9, 2015 05:46 AM
coasterswim
Sep 2, 2015 07:43 AM
A32goldylocks
Sep 2, 2015 06:39 AM
