Can this really happen? What the heck ...
Old Oct 16, 2006 | 02:13 PM
Mints33's Avatar
Ok, my car was getting awesome gas mileage, 21-22 mpg, in town driving, and after I changed the plugs, she's getting under 20 for sure. They're OEM platinum plugs, and I double checked the gap before installing. They were installed about a month ago. Can new plugs kill gas mileage? I've read awhile ago, some member didn't ever change his plugs because he was getting some awesome gas mileage as well, and why kill a good thing. After the new plugs, I noticed her starting up way better and she drives a tad different. But it wasn't till at the pumps, I noticed her being a hog. Any suggestions?
Old Oct 16, 2006 | 02:25 PM
CCS2k1Max's Avatar
SD? When did the weather start getting cold in isoland? Colder weather = worse mileage.
Old Oct 16, 2006 | 02:38 PM
doc2278's Avatar
Doctor D I presume???
colder weather+ new plugs= has nothing to do with poor gas mileage, what grade gas are you using? 89 91 or 93? fill your tires up with air when it got cold? that could be one reason why.
Old Oct 16, 2006 | 02:51 PM
Mints33's Avatar
Always fill up at the same gas station, and always use 91. Yes, tires got filled up w/ air when it got cold, I check my tires regularly, probably weekly, ****? Yes of course, she's my baby. Air filter is new.
Old Oct 16, 2006 | 06:54 PM
YZFR1Tim's Avatar
make sure your tires are not over inflated. also, it sounds like you are talking about ` to 2 mph? that could be a difference in how you drive, the type of 91 gas you use, etc... you may want to throw some fuel injector cleaner in there....
Old Oct 16, 2006 | 09:05 PM
Mints33's Avatar
Is there a brand of fuel injector cleaner you recommend? Any brands to stay away from?
Old Oct 17, 2006 | 04:53 AM
MAXI BLUE 03's Avatar
use BG fuel cleaner, you can get it at some Nissan dealers and Direct Tire sells one that is a step above the one Nissan sells.
$16-$25 a can.
Old Oct 17, 2006 | 05:15 AM
Derrick2k2SE's Avatar
In some states they switch to a winter blend of gas which causes poor milege. If your stations just switched that could explain it.
Old Oct 17, 2006 | 06:43 AM
CCS2k1Max's Avatar
Colder weather = longer open loop operation/lower tire pressures (if unchecked); thus lower mileage. Add short trips and you have a huge decrease in mileage. The plug change is just coincidence.
Old Oct 17, 2006 | 06:59 AM
00Max00's Avatar
To my surprise, I found the car getting better milage on 87 than 93
mkaresh
Mar 12, 2018 06:48 PM
Need help
23
Oct 2, 2015 08:56 AM
sliptap
Sep 30, 2015 05:57 AM
