battery relocation Q
Old Oct 25, 2006 | 05:33 PM
super6's Avatar
woundering is anyone has relocated thier battery to the trunk. i know there are a few boxes/kits avalible from summit racing. wanted to see how others attached the box in thier trunk and ran the wires. any pics???
Old Oct 25, 2006 | 05:35 PM
madmax20019's Avatar
Fire hazard
I recommend you keep it stock.
Old Oct 25, 2006 | 05:39 PM
illlojik's Avatar
I C U
I agree. The lack of a "firewall" in the trunk can be very dangerous should a fire occur or anything awkward like that.
Old Oct 25, 2006 | 06:43 PM
Orgullo's Avatar
$$ Ballin on a Budget $$
Although it might look cool it would be a definite risk. You never know especially if you are the one doing the re-wire. Keep it stock and be safe. If you are dead set on it then I would like to see some pics after you do it.
Old Oct 25, 2006 | 06:50 PM
Succinct's Avatar
Don't Do It!
I agree - keep it stock. I had a trunk-mounted battery as the OEM design in my former car - a 1999 BMW 540 6-speed. And even though that's the way it was meant to be, it was a pain, except for hooking up my subwoofer amp.
The battery had to be vented, and if the vent got blocked or unhooked accidentally, battery acid would leak out, causing all kinds of corrosion trouble. Total PIA. So many times I wished for a normally-located battery on that car....
Old Oct 25, 2006 | 07:11 PM
SoonerFan's Avatar
Cletus
it isnt a fire (or fume) hazard if its inside a box from a place like summit.
ive been meaning to relocate mine for awhile but havent gotten around to it.
Old Oct 25, 2006 | 08:21 PM
shysmax's Avatar
How did u like the 540 6 spd?
Old Oct 25, 2006 | 08:56 PM
AceofSpds's Avatar
wat
and please make shure you get a drycell battery... dont be a ******* and put a plain jane batter back there.
Old Oct 26, 2006 | 04:33 AM
9DTALON's Avatar
I'll have mine re-located in just a week or two. I will take some pics when i'm done for everyone. One big plus is being able to transfer 20-30 lbs. to the rear of the car from the front. Also clears up lots of room under the hood.
Old Oct 26, 2006 | 09:29 PM
Orgullo's Avatar
I would like to see the pics.
However, what are you planning to do with the space? Perhaps run a true CAI or something??? If you aren't going to do anything with it then it's just going to look like Azz IMO.
Old Oct 26, 2006 | 11:18 PM
Wiredmax's Avatar
I have had my battery in the trunk of my car for about a year with no problems, just make sure you get a nice battery box, plus you should use a yellow or red top battery so theres less chance of it leaking, i have been running the yellow top.
Old Oct 26, 2006 | 11:20 PM
Orgullo's Avatar
Can you post up a pic of both your trunk set up and a shot of under the hood now? Thanx.
Old Oct 27, 2006 | 06:00 AM
9DTALON's Avatar
I was going to fabricate my own cai but ended up with some extra money and decided to just buy the injen one instead. I'm still happy having more room under hood. It just makes getting to things easier, and unclutters the engine compartment. The plan is to secure a plastic battery box to the floor of the trunk, and use an optima red top.
Old Oct 27, 2006 | 11:05 PM
Wiredmax's Avatar
I wish i could, my digital camera broke on me 2 weeks ago, but ill see if i can get one of my friends to take them...
Old Oct 28, 2006 | 09:05 AM
absoundlab
I didnt "relocate my battery but I have a 2nd optima in the trunk for my system.
Old Oct 28, 2006 | 09:35 AM
michaelnyden's Avatar
I relocated mine...if you want to do it right/clean, take your time... I just drilled through the trunk body floor where it was level and "crossweighted" the battery from where I sit to offset my weight. I didn't buy a box kit from summit, I bought the taylor/summit kit with the tray and everything else you need, but I have an optima red top so it's sealed therefore I don't have to vent it--worry about fumes...I will try to get pics, but I am terrible at taking pics as even when I sell things on here, I keep promising a pic, but I always forget...and it never happens cause I get busy with other stuff...
gigabyte
Jan 6, 2017 06:05 PM
bigfrank
Oct 1, 2015 12:51 PM
markevans999
Sep 10, 2015 04:29 PM
