Sponsored by:
Sponsored by: CARiD
Engine break In.
Old Oct 25, 2006 | 06:31 PM
Zack342's Avatar
Engine break In.
My car has 12 miles what is the best way to break it in?
Old Oct 25, 2006 | 06:33 PM
matty's Avatar
What car did you get ?
Old Oct 25, 2006 | 06:37 PM
NmexMAX's Avatar
dot dot dot ...
A car with 12 miles
Old Oct 25, 2006 | 06:53 PM
MaxBlack97's Avatar
wha exactly do u mean by whats the best way?
Old Oct 25, 2006 | 06:54 PM
matty's Avatar
I would change the oil alot. Thats just me though.
If it were me, I would do oil changes at 500, then at 1500 then at 2500. Then start yours 3000 mile oil changes. Wait till about 10K to go to Synthetic.
-matt
Old Oct 25, 2006 | 06:57 PM
nismology's Avatar
I would change the oil every 500 miles until 2.5k or so. Also, vary engine speeds as much as possible (very important). Don't baby it, don't abuse it. Use fairly aggressive throttle inputs when accelerating since that pushes the rings out against the cylinder and expedites ring seating.
Old Oct 25, 2006 | 07:00 PM
NmexMAX's Avatar
dot dot dot ...
Should he take it to 8600 RPM, shold he drive @ 140 constantly, how long before he goes to synthetic, how often/when is/are the 1st oil change intervals
Old Oct 26, 2006 | 04:00 AM
Zack342's Avatar
Thanks. I asked the sales guy if its ok switching to synthetic but he didn't know anyone have recommendations. Can I redline it?
2006 G35 Coupe 6MT Blk/BLK
Old Oct 26, 2006 | 04:02 AM
MaximaSE96's Avatar
Maxima Owner
redline everyshift....but change the oil after 500 and 1000 miles......some say ur car will be faster if u pound on it from the gate and also will not affect reliability
Old Oct 26, 2006 | 05:37 AM
NmexMAX's Avatar
dot dot dot ...
.. I would have thought that you knew better than that...
Old Oct 26, 2006 | 06:41 AM
matty's Avatar
Old Oct 26, 2006 | 07:02 AM
Zack342's Avatar
i posted some in OT. I will post more when i pick up the car today.
Old Oct 26, 2006 | 07:23 AM
Kevlo911's Avatar
Kevlo for President
Redline a few times. Change oil at 300-500 miles. Replace with Castrol GTX. Change oil at 3000 miles. Replace with GTX, change again at 7k miles, replace with GTX, change again at 11k miles. Switch to Mobil1 or Amsoil.
The 300-500 miles should have all kinds of driving in it.
Old Oct 26, 2006 | 09:15 AM
deezo's Avatar
Don't redline that shyte. Drive it under 70mph for the first 5 or 6 hundred miles also. I used to have to break in many new cars for Boston Coach and always broke them in easy.
I would follow the oil changes every 500 until 2500 tho.
Old Oct 26, 2006 | 09:29 AM
MaxBlack97's Avatar
y pound on it? Dont u have to break in a mnew clutch for the first 500? The dealership always say to keep it under 70mph for the first 1000k also.
Old Oct 26, 2006 | 09:37 AM
hightuner's Avatar
Nissan maniaco conpulsif
Wow i am amaze that we have to use normal oil for the start and then switch to syntech
didn know that
Old Oct 26, 2006 | 09:54 AM
deezo's Avatar
didn know that
Your motor will wear the most within the first 1000 miles so why waste the money on syn? Just used dyno oil when breaking in a motor.
Old Oct 27, 2006 | 07:08 AM
hightuner's Avatar
is that the real reason ???
Old Oct 27, 2006 | 09:37 AM
i30ds's Avatar
Armed and Dangerous
Congrats!
Lets see some picks of that bad boy!
Old Oct 27, 2006 | 10:10 AM
Zack342's Avatar
i posted them in OT
Old Oct 27, 2006 | 12:05 PM
scrhale's Avatar
I don't like OT forum. Bunch of haters. Nice G ... good luck with it.
Old Oct 28, 2006 | 09:21 PM
MrGone's Avatar
search the general forum
Old Oct 28, 2006 | 09:27 PM
LA02MAX's Avatar
why? his question has already been anwered. Nismology hit the high points...
Old Oct 28, 2006 | 09:30 PM
MrGone's Avatar
I agree on the oil change intervals (or a 500, 2000, begin regular intervals at 5000-6000).
More specifically on the redline thing, do a few 3rd and 4th gear runs, start low and run the gear, slow down, do it again.
Engine load is what is important, not speed.
Although if you are only keeping the car <100,000 it doesn't make a bit of difference and ultimately considering the engine, it doesn't matter.
Old Oct 28, 2006 | 09:49 PM
MrGone's Avatar
For the wrong reasons, load the critical part, not speed. You will have better results with an engine running 70-80% load at <4000rpm pulls than you will with an engine with <20% load going to the limiter.
PS: Don't hit the limiter, hell let off a few hundred shy of it.
Oil changes every 500 miles for the first 2500? A good way to **** a way a lot of oil. Most of the wear happens within the first 500 miles. If someone is determined to change their oil that much do it at 100, 250, 500, 1000, 3000 and start a normal change interval but know that it really isn't making a bit of difference.
Just do what the manual says (which probably is first oil change at 3000 miles, or in that ball park) or ask one of the techs. All the salesman knows is how to get you in the car and out of the lot.
Take it easy in first and second, jolting the **** out of the engine/drivetrain isn't going to help the bearings.
Old Oct 29, 2006 | 04:44 AM
nismology's Avatar
You're right about the oil change intervals i posted. They are excessive. I would change the oil at 500 miles for sure.
And who said anything about high engine speed? I said that engine speed should be varied as much as possible. The worst thing someone can do is stick it in cruise control while the motor is breaking in. This means doing 55, speeding up to 65 or so, coming back down, downshifting one gear, etc.
And yes applying substantial load is important, but only for short bursts to prevent a buildup of heat which can cause glazing.
Old Oct 29, 2006 | 04:51 PM
JeEvE's Avatar
http://www.mototuneusa.com/break_in_secrets.htm
Old Oct 29, 2006 | 07:22 PM
Matt93SE's Avatar
STFU n00b!
Do what Gone said. It's what engine builders have been using for decades and works very well.
the reason you don't use synthetic at first is that there's too little friction and the piston rings take much MUCH longer to seat. you need a certain amount of friction in the engine to get the engine to break in and the rings to seat properly. once it's broken in, then you can switch to synth.
boomerbrian
Oct 31, 2018 10:25 AM
The Wizard
24
Oct 1, 2015 08:47 PM
seesole
Sep 14, 2015 12:38 PM
lowpost99
Sep 8, 2015 05:06 AM
